Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Timer light blinks continuosly,cannot turn on the set
Tried reset button,unplugged tv for 24 hours and retried both again
    Genius:
  • 1,694 Answers
Bad DM module = replace or repair by skilled Mits tech only...
Research my solutions or comment,please....
Posted on Nov 04, 2007
  • Vista Electronics Nov 07, 2007
    Very discouraging rating = was I wrong ?..............T.
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Screen will not light up.standby/timer light blinks continuosly
check for any cold solder on the high voltage section of your tv A high voltage section is located at the power supply section, this is where the power cord is connected.resolder them,the horizontal section it is where the plyback transformer is located resolder them and the CRT board this is the boad that is attatched to the picture tube...good luck
please rate my help..
Jun 04, 2010 | Sony KV-35S42 35" TV
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
Jul 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Timer Button
The tv must of turned on the timer by itself. They do do that sometimes. I suggest leaving it unplugged for 24 hours to reset itself.
If problem persists, you may be able to go to your menu and access the sleep mode timer and set it to 0:00 or OFF
Jul 10, 2009 | JVC AV-27020 TV
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
TV won't turn on
read from other forum. wouldn't hurt to try, unplug the power for 2 days and plug back in again to see if it will turn on.
Mar 10, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
