Washer only buzzs
Kenmore 110.92585100 Only hear a buzzing sound (from Motor?) when turn it on. Please help. randy
  • 2 more comments
  • randarr May 17, 2009
    Vic,
    the buzz comes from the bottom. rather hard to tell as to expose the motor i have to take the cabinet off, which involves disconnecting the "lid open" switch. (How can one get power to motor with cabinet removed?) I get water, so i think it is something else.
    Vic, there are three wires; gray, green-yellow (ground), and brown. Do I jump the gray and brown?
    Vic, I do get water. However, the buzzing sound is definitely coming from the water inlet valve. How do I determine if the motor is hung up? And if it is, how would I go about fixing that?
    Can the problem be the water inlet valve if I'm still getting water?
    Vic,
    It Lives! I am running it thru a whole cycle. i will let you know what happens. Where are you? If you don't live in Hawaii, it must be past bedtime.
    President:
  • 1,136 Answers
HI Randy, It sounds like the motor might be hung up. THe moter has apump on one side of it and soometimes they get plugged and will not let the motor run. Does the buz come from the back or from bottom? If it is from the back, it might be water inlet valve. Do you gat water?
please let me know so I can assist you further.
THankx
Vic
Posted on May 17, 2009
  • 2 more comments
  • Victor
    Victor May 17, 2009
    You can use an insulated wire and jump the lid switch between the two gray wires.
  • Victor
    Victor May 17, 2009
    Yes Sir, that is correct
  • Victor
    Victor May 17, 2009
    yes, it could be going bad. Did the motor start at all when you jumped it? Are you getting both hot and cold water?
  • Victor
    Victor May 17, 2009
    LOL. I am in Michigan and yes It was way past bed time.
    I hope it keeps working. What did you find the problem was?
    Please feel free to rate me so that I know how I am doing to help others.
    Thank
    Vic
When turning on the dryer I only hear a hum or buzz
it sounds like your motor is stuck it might be clogged with lint that gets though into the cabinet and surounds the motor and motor contact try giving it a service vac out around the motor
Dec 01, 2011 | Kenmore 98702 Stacked Washer/Dryer
My washer buzzes when knob is pulled but it will spin just not fill or agitate
sounds to me like either the water faucet at the wall is shut off or their is some sort of restriction to the pipes not allowing the washer to fill
some on here may say that the buzzing will be the motor but since it spins i say bully to them the motor only knows to go to spin or agitate rotation based on on what the timer/control tells it to do if it will turn one direction it would turn the other direction as well. So definently check the water supply to the washer
Oh the buzzing is the solonoid on the valve opening the valve yet since no water coming in you hear the buzzing while you wouldnt hear it since it would be drowned out by the sound of the water coming in
Jul 19, 2011 | Washing Machines
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
My kenmore dryer makes a buzzing noise when I push the on button and will not turn on.
When you press the push to start switch and you hear a buzzing/humming sound, it is the motor that has gone bad and CANNOT come on. PLEASE check the motor to see that IN FACT it is bad and that there is NOT SOMETHING foreign somwhere in the blower wheel or elsewhere stopping the system from freely turning
Nov 20, 2009 | Kenmore Dryers
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washing machine will not turn on when swicth is pull to start , i hear buzzing sound so i know power is going thru the system
1- you must to sure that the cover is closed well
2- if this sound come from motor then the belt of motor may be drop ed and need to mount again
Jun 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Does not drain
The light buzzing of the motor doesn't mean the pump is in good condition and actually is being driven by the motor, in fact a seized synchronous motor can make a convincing buzzing sound and not burn out for a long time. The pump intake could be blocked...
If the symptoms indicate there could be something wrong with the pump then visual confirmation is required and not merely the assumption.
Jun 18, 2017 | Kenmore 24 in. 17052 / 17054 / 17059...
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
