Question about Kenmore 91365 Compact Refrigerator
After a power outage or moving moving refrig it wont cool down
The lite is on and check on this site and use an idea of tapping the side of the control knob cause it may get stuckk and or lose contact etc nothing appreciate any help in middle of remodel and only paid 100 for it cause its a temporary refrig. be nice to have something to store cold items again
    President:
  • 1,136 Answers
HI, Get the model # and I can assist you further.It might be stuck in defrost. Are the fans running? How long has it been plugged in since you moved it?
I can try and help with ansers to these questions.
Thanks
Vic
Posted on May 17, 2009
LG lfx28978 Bottom Freezer cooling, but refrigerator section warm; no ice or frost build up anywhere. Started after an eight hour power failure. Also, fan located behind the unit on the lower right doesn't...
Melissa I think you hit the nail on the head! If it was running great before power outage, and problems started after! Power Surge sounds correct to me! below is a link for the service manual! As for board, sounds likely! Check the board for burnt fuses, I think there is 2. Sorry i can't help You more! Good luck!
LG LFX28978 series Service Manual Table Of Contents
Jul 14, 2017 | LG Refrigerators
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
My ge side by side profile tps24 is not cooling on the refrig side and the body of the refrig is hot. Any ideas?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
Frig or freezer is not cooling
Tap on the freezer knob and see if refrig comes on . If so , replace the freezer thermostat ( piece with the knob ) .
Jun 04, 2010 | Frigidaire FRS23KF5C Side by Side...
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Cooling did not resume after power outage
you need to do a reset on the control by pressing the two top buttons until it resets.
Mar 26, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Kenmore 91365 Compact Refrigerator Logo
180 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
