Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper starter and car alarm with 2 controlls and one got stolen what should I do
  • 33 Answers
The Viper alarms will accept (if I remember correctly), 4 codes at one time. That is, 4 individual remotes, or two remotes two times, or one remote 4 times. So, if you program your remote 4 times, it will essentially remove any previously programmed remotes. Another option, and you'll have to check with your dealer, but I think there is a way to delete ALL remotes, and then program your remaining remote one time, and again, all previously programmed remotes are now removed from memory. This was done by the manufacturer just for such events.
Posted on Jun 04, 2009
Buying a car and the guy pulled out the viper alarm and now there s now fuel pressure what can that be from?
One has nothing to do with the other. The security system only interfaces with the starter wire. Just make sure the starter wire is reconnected and other than that its mechanical.
Oct 15, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
99 5 speed nissan has a viper alarm system that thinks its being stolen can't figure out how to bypass it. car wants to turn over but wont get any sparks which i believe is caused by the alarm system
The common viper alarm systems do not interfere with the spark in a vehicle. They only stop the starter from cranking. Something else is stopping the spark, like a bad cam or crank sensor.
Sep 16, 2011 | Nissan Maxima Cars & Trucks
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
Hope some or all of this helps you!
Dec 15, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper Alarm 3002 2-way on a 2003 Mustang GT. After removing it, my car no longer starts. Please help
if your car doesnt start, maybe when you pulled out the alarm, you didnt connect the starter wire back together
Aug 19, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Lost my Viper key fob alarm is on and cannot start truck. any solution to disable?
Your alarm should have a button that was installed called a valet. What you want to do is put your key in the ignition turn it to the on position (Don't start it) then with the car in the on position hold down the valet button until the led light on the alarm goes solid and you should here the alarm beep twice. now your alarm will be disabled. To reable the alarm do the same thing.
Feb 12, 2010 | Viper Security and Remote Start System...
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Jan 17, 2009 | 791XV The 791XV is a 2-way Security and...
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
544 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
