Question about NetGear WGR614 Wireless Router
Wireless not working with the router
  1. I get internet connection directly into my apartment (no modem with me)
  2. I connected the cable from this internet connection to my router internet slot.
  3. Then I turned ON the router.
  4. A green check mark appears and then after some time it goes off. Power and internet sign are ON.
  5. Now I connect my laptop to the router at any of the LAN slots in router.
  6. Now when I try to access http://192.168.1.1 or routerlogin.net none of the page opens up.
  7. If I now restart the router from the button below antenna then I can access the initial page but after second or third page it again says page cannot be dispalyed or no internet connection found.
  8. I also tried to reboot my laptop but no luck.
Please advice me to configure router for wireless...
Thanks in advance,
Chintan
    Scholar:
  • 193 Answers
K once u log in to router u need to click on w/l settings and
Wireless Settings   Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 01 02 03 04 05 06 07 08 09 10 11   Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID)   Wireless Card Access List   Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit   Security Encryption (WEP) Key Passphrase:   Key 1: Key 2: Key 3: Key 4:
and if u want security password type any 10 digit no which u can easily remember one>and click apply do not hit generate>rate me solved if its helps
Posted on Oct 22, 2007
2 Suggested Answers
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
Problem cisco EA6500 to i-cable router HK
Power off Cable Modem, PC, router, and then disconnected them. Directly connected Cable Modem with PC (Don't connect the router) and power on Cable Modem. When Cable Modem is ready with LED lamps under normal status, also power on PC and try to access Internet service. If Internet service is resumed, please study the router setting of Cable Modem which referred to router's user manual.
Apr 21, 2013 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
Rounter is not working
Firstly please check the connections. The modem should be connected to the "Internet" port on the back of the router. And the computer can be connected to any of the 4 ports of the router. Checked the lights. They should be steady. If you have a cable connection2_bing.gif (cable modem) than you can connect directly to the internet. Else if you are using a DSL connection than you need to configure the router according.
**If this works please rate else let me know in case of further help.**
Jun 29, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Conecting netgar wpn824v2 to cable internet
what exactly do you plug directly in the wall? what kind of connector does it use? an 'f' connector on a coax cable or RJ45 (like a phone plug? if you are using a cable connection you have to have a modem for that to work. if you are using a Ethernet cable tied directly to a jack on the wall you'll have to be sure routers are allowed to connect. or register the router with your provider. be sure your wireless router is getting an address form the internet provider. with out more details i can't give you any more specifics.
-good luck-
Will
compressionconnector.com
Feb 19, 2009 | NetGear DG834G Router
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Internet connection
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
NetGear WGR614 Wireless Router Logo
159 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
