Question about Mtd 22" Yard Machine Push Mower
I hit a rock and bent the blade on a yard machine. Replaced the blade and tried to start the mower, but the start rope doesn't come out all the way and recoils hard as I'm trying to pull it out.
  • parrymom May 17, 2009
    Are you sure? The mower started fine before I replaced the blade.
    Appreciate the help.
  • parrymom May 18, 2009
    Yep, I just figured it out. It's up and running again. Thanks
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
Posted on May 18, 2009
  • 10,865 Answers
In addition to bending the blade, you bent the shaft of the motor. There is no fix to a bent shaft. Therefore you will have to either replace the engine or get a different mower.
Posted on May 17, 2009
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
I ran over a rock mowing the yard. the lawn mower sounds weird
when hitting things the blades get bent as well as the key on the flywheel meets the crankshaft throwing the timing off
Jul 16, 2012 | Garden
I HIT A ROCK AND BENT THE BLADE NOW THE ENGINE HAS A MISS
You mean the engine is vibrating? It sounds like you bent the crankshaft. The cost of a new engine may outweigh your want to repair it. To be sure, take the blade off of the mower and start it up. If you still feel a vibration, then the crankshaft is no good.
Jun 03, 2012 | Garden
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
I hit a rock while mowing and now the mower is vibratating badly? What do I need to Do?
You bent the blade. Therefore you need to by a new blade and install it.
Good Luck!!!!
Wayne
Jun 14, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Bent Shaft???
Check that the blade securing bolt is secure. While you're there, have somone SLOWLY pull the starter rope. It will be obvious if anything is bent to the extent you describe.
If this machine has a blade clutch, engage blades while you do the pull test (DISCONNECT PLUG WIRE!!!!)
May 09, 2010 | Mtd 22" Yard Machine Push Mower
I hit a rock with my push lawnmower. The
Oooh boy, I know you bent the shaft, but why it is blowing oil out the carb, I don't know if I would even bother with the blade, you could go buy the same mower, then you would have some parts. Unless you just bumped it hard enough to throw oil around in there, it might settle down, but it is a long shot. I hit a stump once and bent the crank, it was lights out for that mower. Hope this helps.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
I hit a big rock with my walk behind lawn mower and now it sounds really bad when it is running. Whats is wrong with it?
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Jun 29, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 22 inch mower, I dumped it on its top over the weekend, bent the blade, replaced it, now wont start, did leak oil out of the air filter, cleaned it out real well still wont start
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
410 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
