Battery fine, runs great had trouble two times with nuteral/park saftey switch preventing start in recent past now battery goes dead two days after parking the car man says he can't find the problem after all sorts of tests, Any ideas>
Try this..entirely disconnect the battery and use a ten amp charger as a battery for the car by connecting the charger clamps to the battery cables..be careful to match the polarities red to the positive and black to negative..plug the charger in and listen for a buzzing or see if the guage on the charger pegs to full power..the buzz should show your faulty issue..(relay or switch stuck etc)..
SOURCE: I have a 2000 chevy metro 4 cyl 1.3 the vehicle
thats a good question. very hard problem to fix. i had a 2005 colorado i went through 4 batteries in 3 years. chevy could not find problem. they said i had a drain. never did find it sold vechicle.
SOURCE: battery goes dead when car sits 3-5 days 98 park ave
Obvious that something is drawing down the battery...Put a test light between the negative cable and the negative post of the battery (remove cable first) start pulling fuses till light goes out. That will tell you what system is drawing...you can then begin looking for the actual problem. If all fuses pulled and light remains on ,chances are you have an internal alternator problem.
SOURCE: On Hot days when I park in the sun , the car's
replace the battery hyundai/kia use some pretty crappy batteries i am a kia / hyundai tech and have had to replace batteries when the cars have come off the truck i would buy an interstae or exide and you wont ahve the issue again
SOURCE: Randomly won't start, happened after jumping dead battery
Probably the battery. Take it the chain auto parts place and they will test it for you.
SOURCE: 1999 Volvo S80 T6, Starts blower on its own.
If you are talking about the thermo electric cooling fan, its operation is independent of the car's electical system. It is switched on and off by the engine temperature. When you park, the engine heat soaks upward to heat the thermostat turning the fan on. It will run until the engine cools down and the thermostat switches it off.
Testimonial: "My minds at ease now. :) Thank you."
