Question about Compaq Presario X1000 Notebook
My laptop doesnot turn on
My laptop just shut down in middle of a program, and after that doesnot wont to turn on again, trying to turn on the turn on switch dont light, but I see the light that say it is connected to power, none more.
Can anyone help me????
  • Anonymous Mar 15, 2014
    My laptop shows power light but doesnot turn on
I have a Toshiba Satellite U505 pc laptop that was working earlier today. I was in the middle of showing a video to a friend when it just shut down. I turned it on again and the Toshiba screen showed up...
If that was a video over the internet you may have downloaded a smart virus. ( ie/ tricks the computer in thinking it is safe ). Shut the computer down and restart it in safe mode. F8 or F11 while it is booting up, ( I could never remember! ). Close all residual tabs/web locations and all other programs. Go to the START icon and restart in normal mode. Me thinks that should do it for you.
ash
Sep 25, 2010 | Toshiba Satellite U505-S2940 Notebook
Why does startup repair keep popping up on my laptop when i turn it on my sony laptop
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
May 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
ACRE LAPTOP CONSTANTLY SHUTS DOWN BY ITSELF
It is either an overheating problem where the acer is shutting off to protect the equipment, or it is RAM that has gone bad.
Try cleaning out all the vents and fans as well as you can. If the unit is no longer under warranty, you may want to open it up if you can to ensure a good cleaning. If that is not the problem, I would investigate replacing the RAM.
Apr 06, 2010 | Acer Aspire 6930-6771 Laptop
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Shuts down in middle of session; overheating??
no...u have a problem in hardware and is not working as good so try this 1st trouble(1) remove the memory then make a clean(2) remove the mini HDDrive then put it back again(3) if their a same again a problems,last step (4) you need to make a re-programs or re-install the Windows/OS...Good Luck and Have a nice Day..^_^
May 20, 2009 | Dell Inspiron 1501 Notebook
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
Acer aspire 5630 wont turn on
reinstall os from cd.by shutting down in that manner he was probably in the middle of something and didnt close the program resulting in missing sys32 files which is why it wont start.this type of thing happens often and not only for that reason.
do you get anything at all on screen .
can u enter setup(bios)
try removing memory ,make sure free from dust and replace.
no screen is either missing memory,fault with hd(bad sectors)
fault with bios(hardly ever),damaged or dislodged graphics card or damaged cpu(processor)
Apr 12, 2008 | Acer Aspire 5630 Notebook
Wont turn on
sounds **** dead ram. dry replacing the rem. if theres more than one stick of ram then try it individually with each stick. it could be only one isnt working.
Mar 30, 2007 | Acer TravelMate 529ATX Notebook
Compaq Presario X1000 Notebook Logo
129 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
