SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
SOURCE: h5 erreur sharp AR-5516
if there is a paper jam in the fixing many times this err will be displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 and then start button.
