Question about Pool & Spa
How do i light my dega 100 mj spa heater. It says I have power (yellow) light - but does not say heater is on
  • 139 Answers
If it has a yellowlight chances are it is an electronic ignition system.need more info
Posted on Jun 21, 2009
I hope someone can answer this we have the same heater but cannot work out why it is not heating yellow light is on it appears to be in heat mode but it isn't heating up
Posted on Dec 12, 2014
Need to change coolant recovery tank can a anyone do it
Yes you can do it yourself
Degas Bottle Removal
  1. Drain radiator (8005) until engine coolant is out of degas bottle. Disconnect radiator overflow hose (8075) and engine coolant vent hose at degas bottle.
  1. Remove power steering oil reservoir retaining screws and position power steering oil reservoir (3A697) out of the way.
  1. Remove degas bottle return hose and clamp. Remove degas bottle retainers and remove degas bottle.
Installation
  1. Position degas bottle in vehicle and install retaining screw and nut. Tighten retaining bolt and nut to 9-12 Nm (80-106 lb-in).
  1. Connect degas bottle hose and clamp to degas bottle.
  1. Position power steering oil reservoir onto degas bottle and install retaining screws securely.
  1. Connect radiator overflow hose and engine coolant vent hose to degas bottle.
  1. Fill and bleed engine cooling system as described. Check for coolant leaks and proper engine coolant level after engine reaches normal operating temperature.
    Item Part Number Description 1 8100 Radiator Cap 2 - Nut (1 Req'd) 3 - Bolt and Retainer (1 Req'd) 4 - Nut (1 Req'd) 5 - Bolt (1 Req'd) 6 - Coolant Recovery Hose 7 - Coolant Return Hose 8 - Coolant Recovery Hose 9 8A808 Degas Bottle A - Tighten to 9-12 Nm (80-106 Lb-In)
Hope this helps.
Zeppelinx12
Mar 08, 2011 | 1999 Ford Taurus
Hello, please tell me what breaker (amps) do I need to use with Hayward 11kw Electric Spa Hot Tub Heater Cspaxi11. What is the normal amp consumption for this equipment? Thanks
Hi and welcoe to FixYa, I am Kelly.
11,000W is the maximum power that it could draw. Given the wattage is over 10,000 I am certain that your Spa / Tub heater is 220 VAC If it is 220 VAC then you will need a 50 Amp breaker. If it only 110 VAC you will need a 100 Amp Breaker. (Gasp!)
Amp consumption will always vary.
Heater on / Off
Number of Blowers and pumps in operation at any given time. Then add lights to the equation. My best guess at any given time it is in "full operation" it will average 6,000 - 7,500 watts. When not in full use it the average amp usage would drop substantially.
Thanks for choosing FixYa,
Kelly
Feb 21, 2011 | Hayward 11kw Electric Spa Hot Tub Heater...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Pool & Spa Logo
551 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
