Question about HP Compaq nx5000 Notebook
Will not show anything after log in
Will start up and can log in, but will do nothing after blue screen comes on
  • 27 Answers
Just before the Windows logo screen appears press F8 and chose "Last Known Good Configuration", see what happens it might fix any driver related issue. If not you can try "safe mode" from the F8 menu and see does that boot.
Posted on May 17, 2009
All my tv shows a a blue screen nothing else even when I press input
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2015 | Televison & Video
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
It just stopped working right
hello, can you still log in "safe-mode"?? is yes loging using safe mode with networking and see if the internet and open control panel.
if yes, download combofix from here,
http://www.combofix.org/downloadlink.php
save the file with random letters and numbers (ie "hdshh767.exe") close all other windows and double click and run it. follow on screen instructions and make SURE while combofix is running nothing is touched on that PC and absolutely no clicking in the BLUE windows that combofix is working in.
it can 15-20 mins or maybe even more if there is lot of junk on the PC.
at the end a log files prepared and opened which help you identify if there was an infections of some sort.
let us me know how that works out or if you need more help..
good luck,
regards, Amar Sondhi
Dec 04, 2009 | Dell Inspiron 531s Desktop Computer
Cant login to computer
That is a windows issue. If You have different names on the login screen try one of those. Try to get in then do a system restore.
May 25, 2009 | Medion M3 Director 5100 PC Desktop
MV750i playback
Hi.
Do you get an image come up on the tft screen or the viewfinder, when you put the 'corder in rec mode?
Sep 25, 2008 | Canon MV750i Mini DV Digital Camcorder
Hardware problem
Your memory is broken it's need to be replaced!
Jun 24, 2008 | Compaq Presario Notebook
EVO N600c starts up fine but when when its time to sign in nothing on screen just blank
Both of you, what did you do before the restart? If you changed anything while in Winblows it seems likely it is a software related issue. If you didn't, then a hardware issue is possible, in which case I'd start by unplugging the non-essential peripherals and restart. If that doesn't work, also try a different power supply and disconnect the battery. Sometimes a bad peripheral can cause the boot up sequence to hang. And correct me if I'm wrong, but I believe a weak psu can undersupply power to the harddrive causing the operating system to fail to boot. But, you probably have tried these ideas so they may not be of much help. Oh well, good luck!
Jun 23, 2008 | Compaq EVO N600C (Refurbished) 14.1" LCD...
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Jan 30, 2008 | Polaroid PDV-0701A Portable DVD Player
HP Compaq nx5000 Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
