Question about Sylvania LC260SS8 26 in. LCD Television
How can you change the resolution on the sylvania lc260ss8?
How do you change the resolution on the sylvania lc260ss8?
  • Jim Krause May 11, 2010
    What resolution are you referring to? Your set can accept 720P.
4 Suggested Answers
PAINguin
SOURCE: Comcast remote code
Guys, I checked in my booklet that came with the comcast remote. I could not get any of the codes online to work but the first one in the Comcast booklet did.
The codes listed for the Toshiba LCD TV's are: 10845 and 11656
The first one worked for me...
Remember, on your comcast remote. Press the tv button once, hold setup until the tv button flashes twice then enter the code.
If you enter the code correctly then the TV button will blink twice. If not, repeat the entire process.
If the TV button blinks twice after entering your code the hit the power button. If the tv goes off you know you are good to go!!!
Hope this helps!!!
Posted on Mar 11, 2009
dsacco86
  • 1077 Answers
SOURCE: Sylvania LC260SS8 -No power, will not turn on
The most likely your right, the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
taran_2005
  • 10515 Answers
SOURCE: when I turn on my
I am sorry to hear regarding the trouble.
The totally white screen you are talking about is a good indication of LCD panel failure.
Actually the Tcon board(timing control board) on the LCD panel itself can be defective.This is a little board converting the signal from the main board into a format that can address the LCD panel.
This board is mostly sold with the LCD panel together,as an assembly,but sometimes it is available separately.
The cost of the LCD panel would be so high,that it will exceed the cost of a new unit,but if the Tcon board is available it is worth a shot to replace it (it might save your tv).
The cost of a Tcon board like that is not so high,about $100.
Add another $80-$100 labor fee and the tv is still worth repairing it.
If you need a part# for this Tcon board,please provide the unit's serial#,to identify correct the part#(for some ,there is no part# available,the Tcon is part of the LCD panel!).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 24, 2011
Turns off then back
It is likely that the power supply is failing but revives periodically
Jun 18, 2013 | Sylvania LC260SS8 26 in. LCD Television
Type your problem for a solution...Turn it on.....screen stays blue.......none of control buttons work.....to turn it off must unplug from walll
If unplugging did not fix the issue you have a problem related to the microprocessor in the set---it may not be bad but be getting bad info from somewhere in the set.
Not likely to be a do it yourself repair.
May 17, 2012 | Sylvania LC260SS8 26 in. LCD Television
I purchased a sylvania 26" lcd hdtv and i have
in your warranty should be a list of certified service shops that you can go to. Usually it is at the end of it, last pages. Also, you will need your original receipt when you bought the TV. If you cannot find the service number or location, call the shop where you bought the TV and ask for it. DONT say your warranty is about to expire because they might try to trick you.
I believe that those black lines are malfunction that your warranty covers, be sure to do it tomorrow!
Hope I helped, thanks for using FixYa!
Aug 07, 2011 | Sylvania LC260SS8 26 in. LCD Television
I have a 26" Sylvania LCD TV that won't power up. Only a rapid flashing amber power light. Is that the light source gone bad - burned out ? Thanks MC
There is a diode located on the power supply of this set that has been a common problem. The location number of the diode is d558. If it is shorted then it will need to be replaced. There could also be other possibilities but this the most common problem that I have found in my notes. If this is the problem, a repair shop may get any where from $50-$150 to fix it. If you did it yourself, the diode would only cost a couple of dollars.
Jul 29, 2010 | Sylvania LC260SS8 26 in. LCD Television
Tv codes for my sylvania tv for a universal remote
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Feb 05, 2010 | Sylvania LC260SS8 26 in. LCD Television
Jun 28, 2009 | Sylvania LC260SS8 26 in. LCD Television
POWERING ON
good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Oct 09, 2008 | Sylvania LC260SS8 26 in. LCD Television
Sylvania LC260SS8 26 in. LCD Television Logo
270 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
