Question about Packard Bell (ATXMH28AP) Full Tower Case
Momentary switch won't turn on pc
Computer won't turn on with power supply connected to the psu have checked psu Psu checks out ok . No responce from momentary switch when pressed. Can you solve this problame for me please . Trevor.
    Problem Solver:
  • 9 Answers
Open the computer and check the cable that comes from the power switch and goes to the front panel header on the motherboard. Make sure it is connected. If it is, you need to check if the switch is working. Two ways: check resistence at the end where it connects to the motherboard with it disconnected and turn switch on and off. If you don't have a ohm meter, you can also short the two pins that the power switch cable connects to. If it still doesn't power up, then it can be three things. The memory, or the cpu, or the motherboard. Swap each one at time until you determine what is causing the problem.
Posted on May 18, 2009
Dell Inspiron desktop, will not power up.
hi!,
ok, is there any voltage appear in one of the terminal of psu or power supply is the fan of psu is running,if you suspected your psu is running or not try to unplug and disconnect your psu from the mother board,then bigger socket that contain 24 pin with different color of your psu try to connect the two pin that has a color blue and green by a small wire about 2 inches slotted at both end.then put power if the fan is run its good may be your memory or video card or processor is defected if your psu does not run replace.
Mar 05, 2012 | Dell Dimension 3100 PC Desktop
Standby blinking green button went off and now cannot turn on. cord connection ok and eveything unplugged that might interfere
I guess your power supply died. try to disable the power supply and enable it again (switch behind the tower) otherwise you should get it checked out by a professional.
Mar 02, 2011 | Dell Dimension 4700C PC Desktop
Computer won't power up unless I jump pin 16 and 17 at the 24 pin connector at the motherboard. After I jump it, it runs till I shut it down. It will power up on a few more start ups but soon goes back to...
a real answer. not bs above.
you proved the PSU is ok, why go there?
the why this works is the chip called South bridge.
does all this (this is how (also) the windows start button and shut off works, called SOFT POWER OFF)
the button on the front panel is a N.O SPST switch.
normally open momentary and shorts a specific and non world standard pin on that mobo to ground, (adjacent pin)
this sends a logic zero state (0v) to the South bridge
then it turns on a transistor on that mobo and that grounds pin 16 to PSU, and PSU magcially turns on.,
end theory101....
the problem can be ; the switch is plugged in wrong. or bad.
HP uses vast numbers of MOBO in PCs so have all different pinouts. and hard super hard to trace and learn that.!
all mine are keyed, and the mobo is silk-screened painted, Front panel.
the other possible is that the PSU is not putting out standby power
on pin 9, with PSU plugged into the wall pin 9 must be at 5vdc.
if not the South Bridge will be dead.
as will the power switch it supports
http://www.pcdied.com/power.html
The South bridge runs power. managment.
the 945P must have PSU standby power and the switch most reach its power on pin, or there will be no working switch ever.
The PC can also force the PSU off if one of the onboard
power regulators are reading wrong (say too high)
The power management is complex, but not that one pin,.below.
Power management,
wake on LAN, sleep, hibernate. and more.
but all we care is the power switch but if the above features work then the switch is bad, and why I mention that.
my PC can even self turn on at 6am if I want, (a bios features) self power on...
now the list of simple..tests,etc.
1: PSU pin 9 must be 5vdc at all times, wall plug aC connected.
and if read of PSU has a switch, set to logic 1 , (1/0 labled)
means on.
2: the correct working switch in front panel,
2b< that switch must be on the correct jack on the mobo and not off one pin or some other ERROR. there.
3:the PSU good ... some are not, (complex reasons) skip i will.
4: the MOBO most be good, (and not overheated)
Switch.
will the PSU turn on if dvd/cd drive and HDD drive cables pulled.?
even pull RAM. sticks? it will beep like mad but will turn on.
and be dead but turns on. like that. well most do.
5: jump the pin below, does that turn on the PC? as it must!
A DT PC 12 years old now.
m7480n this PC is now retired at HP means zero support.
no service book but it lacked the power jack info in most cases
DATA: (first know what is there, the mobo is clearly labeled. look?
this is the best search I did for you,at HP real, yours
  • Manufacturer: Asus
  • Motherboard Name: P5LP-LE
  • HP/Compaq motherboard name: Emery-UL8E
ive owned many P5 in my life, not now but am an ASUS guy.
but this old board we can do research on it,
I like HP and HP likes ASUS as do I. both.
knowing this fact
we see
Asus Leonite P5LP-LE User Manual
then we find the book on it next like this, (took me 1second )
page 5 shows layout
https://www.manualslib.com/download/449087/Asus-Leonite-P5lp-Le.html
bottom right shows, (F_panel) Bingo, on jack.
page 25 covers that jack
so pull the jack there pull plug from jack
then jump pin gnd /pwr pins with screw driver tip.
if PC turns on the switch was bad or plugged in wrong,
if not the PSU is dead, Standby power is dead, pin 9
p25-0kaf4dlf4nbtfyx5ejcudwbi-5-0.jpg Asus books always show all this, but never HP for some odd reason. (details like this)
good luck
Nov 07, 2017 | HP Pavilion m7480n (882780389410) PC...
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU...
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Jul 28, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
System hangs upright after Dell logo appears
You will have to troubleshoot and find out where the fault is. Here is what I do….. First, check the Power is ON, cable is OK and IN PC, Then open PC up, and remove all power connections from everything EXCEPT the Motherboard Connector.(s) (Remember where they go, draw a diagram etc) Power the computer up, and does it switch on? NO, Then, remove the RAM, does it Boot up? YES Faulty RAM, replace. If it still does NOT then your Power Supply Unit is probably Faulty.(But it may be the motherboard) either way we need to test more with a known good power supply. With know good PSU, plug this one into the Motherboard Connection(s). Does it work, YES. Problem Solved. OK back to Frst: Because it DID go the PSU WAS OK, The MB was OK & the RAM was OK, Now then we plug in each of the other Items, DVD Hard Drive, etc, etc. One-at-a-time, until we find the one that stops the PSU. (It has protection and will "Shutdown in event of a fault") The one that stops the PSU is your culprit, replace whatever it is.
Mar 28, 2010 | Dell Dimension 3000 PC Desktop
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Broken power button on a gateway t-series
Usually it is the Power Supply or The components of the PC. You will have to troubleshoot. To find the exact culprit.
Feb 03, 2010 | Computers & Internet
I have the same problem with my Gateway 700x, appears in sleep mode and the keyboard and mouse so no power to them. I need to get this computer up and running again so I can access the desktop programs to...
OK, this is a fairly common problem. It should be an easy fix.
The PSU inside ya Case should have a "Wattage" printed clearly on alabel, perhaps 300Watts 500Watts, whatever, get any suitable PSU that has the same or higher specs, and that fits the screw patterns.
Check the Fan in the PSU... if it is NOT spinning when the Power button is pressed, or at least sorta "Pulse" at switch on, the odds on ya PSU is kaput. First remove all PSU connections EXCEPT for the Motherboard one and see if it will power up, if so, the turn off and reconnect each device in turn and check, IF after ya connect a device and it win't start then THAT is ya faulty bit, replace. If not, then ya gonna have to replace the PSU.
Generally, ALL PSU are the same with a few exceptions.
I generally Plug it all in B4 I actually "Button it up". To prove it was the PSU, as, sometimes it is something faulty, causing the PSU to NOT start up.
Replacement is easy. You simply carefull remove all the power Conns from Motherboard, Drives, DVD etc. then remove the 4 screws holding the PSU. Then install the replacement, reverse order.
Jan 18, 2010 | Gateway 700 X PC Desktop
How can I test FSP250-60 ATV power supply to see if it works or not? Can I test it before I buy a replacement unit? Computer will not power up. Alredy switched power cords several times...and it still...
A great way to test a PSU is to use a PSU Tester. The device allows you to see if all the circuits are getting power and it only requires you to plug it in to power. This allows the ability to test it safe and reliably without accidentally damaging hardware. Below is a link to a tester.
PSU Tester
Feb 03, 2009 | AOpen Computers & Internet
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Jan 28, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Computers & Internet Logo
360 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
