Question about Sony KP-53V90 53" Rear Projection Television
Color issues - Sony KP-53V90 53 in. Projection Television
My parents have a Sony KP-53V90 that has developed some color problems. The overall color seems to be much more yellow than normal and also nowhere near as sharp as it used to be. The TV had really good color and image quality until this problem just happened one day.
Any thoughts/recommendations??
Thanks,
Theo
  • 317 Answers
SOURCE: Projection TV has "green" screen when should be black
call tech ..suggest screen adj.
Posted on Nov 26, 2007
ladywinn
  • 5138 Answers
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Posted on Jan 09, 2008
Ecollier2012
  • 3459 Answers
SOURCE: color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Posted on Apr 17, 2009
tvrepairbiz
  • 63 Answers
SOURCE: sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Posted on Sep 03, 2009
Testimonial: "thank you!"
2001 Sony KP-53V90 53 in. Rear Projection Television has a problem related only to the picture, the top and bottom of the screen are bowed into the middle, the video feed label and volume scale are also...
This is probably the notorious "light engine" problem that all of these Sonys of this design run into sooner or later. It is usually more expensive to repair that what the TV is worth, sadly. A Sony authorized repair center can confirm this.
Feb 18, 2011 | Sony KP-53V90 53" Rear Projection...
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
I HAVE A SONY KP-53V90 53 INCH REAR PROJECTION TV AND THE COLORES ARE NOT MERGING TOGETHER PROPERLY I THINK THIS IS CALLED A GHOST IMAGE HOW CAN I FIX THIS
You have a convergence issue, will have to check convergence IC,S or just replace them there are usually two of them mounted on heat sinks they are usually STK'S with a number after. Also must check fuseable resistors supplying +15 and - 15 volt s to the chips. After replacement some convergence alignment may be needed. Good Luck.
Mike
Apr 15, 2010 | Sony KP-53V90 53" Rear Projection...
I have a Sony KP-53V90 53 with no display and red light flashing
This is a good one. Your TV "looks" at the feedback coming from each picture tube in your TV. When it doesn't see what it expects, it kicks out a 5 flash. Most commonly, the correct signals never got to the picture tube(s) and that's why the feedback was abnormal. Which brings us to the most common solution: C boards, they attach directly to the bottom of the picture tubes. Figuring out which one has a problem... that's another matter. Due to the age of the TV, parts costs are rising. Each C board (3 in the TV) runs about $100 so guess work can be expensive. I hope this was helpful.
Mar 28, 2010 | Sony KP-53V90 53" Rear Projection...
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
Jan 14, 2010 | Sony KP-53V90 53" Rear Projection...
Color not working on 53" rear projection sony tv made in 2000 looks like color is all green is it a tube because of the year
there's a slight possibility it might be your video board, i recommend disocuntdashmerchantdotcom for free troubleshooting :)
Jul 01, 2009 | Sony KP-53V90 53" Rear Projection...
Remote control does not work.
In Sony KP-53V90 TV, Remote Sensor (IR) is located in HC board and an exploded view is pasted here for reference.
Sep 28, 2008 | Sony KP-53V90 53" Rear Projection...
Turns on, blinks 8 times, turns off
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Feb 11, 2008 | Sony KP-53V90 53" Rear Projection...
NO AUDIO OR AUDIO GOES IN AND OUT
problem is defective part on audio bd., either audio I.C. or a bad resistor or capacitor on the output side of the I.C.
Dec 30, 2007 | Sony KP-53V90 53" Rear Projection...
Sony KP-53V90 53" Rear Projection Television Logo
516 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
