Question about Sharp Wizard OZ-590A
I CHANGED THE BATTERIES
I PUT IN THE NEW BATTERIES AND NOW I CAN'T TURN IT ON
  • goodchild Nov 19, 2007
    put new battery in...hit the reset on the back...on the front it just says system reset...clear all data yes or no....will not respond to any thing else that is done.
Have you placed the switch on the back to normal operation
Posted on Nov 04, 2007
SOURCE:
Won't turn on after changing to new batteries
Did you put the batteries in correctly? It could be that simple.
Mar 20, 2014 | Brother P-touch PT-90 Personal Label Maker
Airwell remote
maybe the button for turn on is blocked
Dec 10, 2013 | Heating & Cooling
On My garmin gps 72H none of the buttons will work. EG I cannot change pages or turn off. Was working fine then changed batteries and this occured. Any suggestions??
I would read the owner manual first and then remove the batteries for a while and put back. This does not use recharge able batteries?
Nov 03, 2012 | Garmin GPS 72 GPS Receiver
Code has been changed and battery is flat
Try taking the batteries out and put them in again. Also try to clean the contacts with a pencil erasser. Try putting in new batteries.
If you have the turn knob inside the door check to see if the plastic isn't cracked (broken) if it is that would stop your batteries from working.
Oct 27, 2010 | Locks & Locksmithing
It won't turn on. I've put new batteries in 4months ago and it worked fine. And when school was over, I didn't used it all summer. But now when a new semister started, I needed to use my Calculator again...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please append a comment to this post and we'll go on from there.
Sep 05, 2010 | Texas Instruments TI-84 Plus Calculator
My logitech wireless usb mouse will not turn on at all. I have even changed the battery and still wont turn on. i made sure the batteries were in correctly and i just wont turn on. I was using it and it...
I'm having the same problem, connecting isn't the problem, its just that the mouse won't even respond to the batteries being put in. Bought fresh new batteries, still no luck :\
Sep 25, 2009 | Logitech Cordless Mouse
Kid Tough Digital Camera Error 50
It sounds like your rechargable batteries might be bad.
Try a new set of batteries. It might be a cheap fix.
If this helps please vote for my solution.
Aug 27, 2009 | Fisher-Price Kid Tough Digital Camera
I have a pls3 yellow laser and when i've changed the batteries it is completely dead
have you got the batteries in right?if it worked before you changed batteries,then the new batteries may have been put in wrong or the new batteries might not be any good.check
Mar 15, 2009 | Pacific Laser Systems Pls 20309 Tripod For...
It doesn't turn on
mine did the same thing and i put new batteries in and held image review buton while pressing power and it turned on
Mar 20, 2008 | Nikon Coolpix 5600 Digital Camera
Wont turn on!!!
My problem is this; i changed the battery after i had signal that battery should be changed. I changed the batteries with new one but when i press the on/off button, the camera will turn on.
I put in new batteries again and is still the same problem.
Mar 11, 2007 | Vivitar ViviCam 3765 Digital Camera
Sharp Wizard OZ-590A Logo
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ekse
Siul Oyaratgam
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
