Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Briggs&Stratton 4.5hp seeking/hunting
Model 10G902-0171-B1-02120254.
I removed/cleaned the carb and tank and cleaned the air filter and it has a new plug. New fuel for this season. It runs great for about five seconds then gradually starts to seek/hunt. It's very pronounced. The engine dies while slowing down, then revs back up. I have a video where you can see the little dealie, behind the carb, moving back and forth.
It will gradually run worse and worse over about two minutes before dying. It seems to like running best when I lift it up, by pushing down on the handle.
If this site will let me post a video, I will give you the link. Audio is terrible... cell phone. Otherwise, I will post it on YouTube and tell you what to search for, to find it easily. This is really annoying because my lawn is getting huge/out-of-control/embarrassing.
Search for these tag words, on YouTube:
ASDFG B&S mower surging/seeking/hunting
  • dbuschhorn May 17, 2009
    I cleaned the screens, with air but they were pretty clear to begin with. Will try the diaphragm. Is that at the other end of the arm that I can see slowly moving back and forth while the mower is seeking?
    I just ordered it. Part number has changed but It's all good. Will let you know if it works :)
  • 376 Answers
Did you replace the pump diaphragm and gasket between the carb and fuel tank? There is also a screen on the carb and a secondary pickup 'hole' on the fuel tank that needs to be cleaned between them too. You'll see that when you take the carb off the tank.
Posted on May 17, 2009
  • 1 more comment
  • Dwain Pippen May 17, 2009
    Remember when you replace the pump diaphragm to put the rubber diaphragm against the fuel tank and the gasket on TOP next to the carb
    No. You have to remove the fuel tank and carb. Then, unscrew the carb from the fuel tank and pull them apart. Then you will see what I was talking about in the last posts. You will have to buy diaphragm part #495770
    Cool. That usually works on those engines. Slip the screen off the pickup on the carb and clean it and the chamber it fits into and remember the rubber diaphragm goes against the tank. Let me know how it works out.. Dwain
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
I have A briggs & stratton 300 engine. When I start the motor surges at idle and full throttle.
Leaking head gasket or intake gasket
Try a new spark plug & fresh fuel first,
& clean the air filter
Sep 26, 2014 | ROPER OUTDOOR POWER PRODUCTS Weedeater 20"...
Describe your Briggs Stratton Lawnmower Lawn Mower Short Block Problem. I have model# 11A-414E765 Lawn Mower. Starts ok but is surging and when I checked a brand new spark plug it was full of black dust...
I am pretty sure this is a 4.5 Hp engine with the carb on top of the tank. Plastic carb 4 or 5 mounting screws mating carb to tank. Remove the air cleaner... and tighten the carb to fuel tank mating screws. It is drawing air between the tank and the carb. This should stop the surging. If is has been a long period that you used the mower with the surging problem the diaphragm between the tank and the carb may be either out of position or damaged. The diaphragm is not expensive. Usually the first time this symptom presents itself you can resolve it by tightening the carb to tank scresw. IF you have the primer bulb carb..mash the rubber of the bulb against the carb body. If the surging stops... the primber bulb has a pin hole in it.
You passed the mower model number and not the engine model number. When we use the 11A number you passed all we get is the base and handle parts. If you need more help I need the model number off the engine just above the spark plug wire on the air shroud.
Thanks for choosing Fixya,
Kelly
Aug 31, 2011 | Briggs & Stratton Briggs Stratton...
I have a morrison classic 35 that is surging while its running, it runs well except for the surging. am guessing plug gap is 20thou and have cleaned everything. it seems to be the arm that comes off the...
Your Briggs & Stratton Classic engine uses a diaphragm to pump fuel. Yours has deformed and needs to be replaced. It is a very easy repair. Remove the air filter. There is a bolt on the end of the fuel tank nearest the spark plug. Remove this bolt. There is another bolt just behind the carburetor that holds the tank to the engine. Remove this bolt also. Now you should be able to gently pull the tank away from the engine. After the carb clears the intake tube, you can tilt the tank enough to remove the governor linkage from the carb butterfly shaft. Now the tank/carb assembly is loose and in your hand. Go to the workbench. There are 5 screws that hold the carb to the tank. Remove these 5 screws. When you lift the carb from the tank, you will see the diaphragm gaskets. Remove the old and install the new set. The 2 part diaphragm set consists of a rubber diaphragm and a paper gasket. The rubber part goes against the tank, then the paper gasket, then the carb. Leave the screws in the carb as you reinstall it, and the screw tips will align all parts during reassembly.
The diaphragm set is readily available at any Briggs parts dealer or online. Make sure you take the Model, Type, & Code numbers with you when you go for parts. These numbers are stamped into the metal fan shroud just above the spark plug.
Dec 31, 2010 | Briggs & Stratton Garden
The engine starts ok but it keeps revving up and down, as though its about to conk out, although, so far, it hasn't. It has also started to blow out some white smoke? I have changed the spark plug - but...
Your Briggs & Stratton has a Sprint or Classic motor on it. Every few years, the diaphragm in the carburetor must be replaced.
Briggs part #495770
1. Remove the air filter assembly. This is a good time to clean and re-oil the filter.
2. Remove the 3/8" head bolt from the front of the fuel tank.
3. Remove the 1/2" head bolt from the side of the fuel tank.
4. Gently pull the fuel tank assembly toward you and tilt it away from you. While doing this, you will need to unhook the governor wire from the throttle plate.
5. Drain the gasoline (you can use it again later)
6. Remove the 5 screws that hold the carburetor on top of the fuel tank.
7. Pull the carb straight up. Be careful not to lose the spring or strainer on the bottom of the carb.
8. Remove the diaphragm.
9. Clean the carb and tank surfaces with carb cleaner spray.
10. Open the package with the new diaphragm in it. You will find 2 pieces. One is rubber, the other is paper.
11. Place the rubber diaphragm onto the fuel tank, then the paper one. Gently reinstall the carb onto the tank.
12. Push the 5 screws back into the carb. Before you tighten any of the screws, have all 5 pushed through and wiggle the carb a little, this will allow the diaphragm to align properly. Tighten the screws.
13. Reinstall the tank/carb assembly. Make sure you hook up the governor linkage.
14. Inspect the governor spring(s). They should be connected on both ends. You should not disconnect them for this repair.
15. Reinstall the air filter, gas, prime, and GO!
Good Luck!
Oct 25, 2010 | Briggs & Stratton Garden
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Briggs & stratton 35 classic mower.(mcculloch m3540p) starts rarely and only 4 a short time. Shows spark at plug fuel getting through air filter ceaned.(tried without air filter to no avail.checked...
With the air cleaner removed, see if the engine will run for even a short time when you give a couple of quick squirts of starter fluid into the carb.
If it runs with that, the orifices inside the carb are dirty and need the gunk cleaned out.
Before extended storage, always drain/use up all the gas in the tank and run the engine til the carb runs out of gas.
Sep 21, 2017 | Garden
Briggs & stratton engine
That being the case...your miss is fuel related. Your mix is too rich..(too much gas...lack of air)...as the tank empties, your mix will lean out, basically telling you what the problem is. I recommend that you first clean the air filter, as this can cause the engine to **** too much gas. After cleaning, if you can tell no difference, the next step would be to adust the car...(air bleed). If this doesn't work, remove the carb soak in carb cleaner, blow out with compressed air, and install a new carb kit, (seals gaskets, and new seat if equipt with a needle valve and float. Good Luck! I hope you find this to be very helpful!
Apr 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
856 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Roland W VanLue
Roland W VanLue
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
