Question about Maytag 24 in. MDB4100 Built-in Dishwasher
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
WHEN THE WASH CYCLE STARTS THE WATER FILLS BUT AFTER THE FIRST DRAIN THE WATER DOESN'T FILL ON THE REST OF THE CYCLES. IF YOU TURN TO ANOTHER CYCLE IT STILL DOESN'T FILL.
IF YOU TURN THE TIMER TO OFF FOR A WHILE THEN TURN IT TO A WASH OR RINSE CYCLE IT WILL FILL THE FIRST TIME THEM NO MORE.
  • 4 more comments
  • llsummers528 May 17, 2009
    it sounds like it trying to do something
    this is a dishwasher but i'm not sure if the sprayer arms are moving or not.
    so this valve will work sometimes and not others? i took that valve out and applied 120 volt to it and got water to come out.
    on the other hand i had a tester on the vavle and cycled the timer and got voltage to the valve but no water. i assumed something else might be causing this not to let water go through it like a switch somewhere.
    maytag mdb4100awx
    i appreciate your help...give me the 800# and i will call them for $ and availability.
    what part number do i need to use? where do you ship these from?
    President:
  • 1,136 Answers
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
Posted on May 17, 2009
  • 6 more comments
  • Victor
    Victor May 17, 2009
    Is it a faint hum or is the agitator actualy moving back and forth?
  • Victor
    Victor May 17, 2009
    Ok, Sorry I miss understood. It sounds like the inlet vavle is over heating and will not open until it cools down. You can find the inlet valve behind the panel (front left corner) below the door. If you remove that panel. you can start the d/w and listen for the valve. The other option is to put a voltage meter inthe connector to the valve and watch the readings later in the cycle. If you get 120V and no water. change the valve.
    I hope this helps
    Vic
  • Victor
    Victor May 17, 2009
    Nope, If you have voltage, yyou should have water. What brand/model# is this? If it is whirlpool my sight is www.whirlpoolpartssurplus.com
  • Victor
    Victor May 17, 2009
    ok.. I can get that one also. If you want it, we can send it to you. I will give you our 800 # if ya like
  • Victor
    Victor May 17, 2009
    I have it on my site for 32.95
  • Victor
    Victor May 17, 2009
    It is on me web site at www.whirlpoolpartssurplus.com and we have them in stock. 1 866 798-4375
  • Victor
    Victor May 17, 2009
    I am sorry, I fotgot to give you the Part#99001359
  • Victor
    Victor May 17, 2009
    We are located in Michigan. We can ship ups or regular mail. THe part is on the web site now. I am sorry, I fotgot to give you the Part#99001359
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
I have a Maytag Neptune TL (FAV6800AWQ , Serial # 10178127EC) that starts and stops after the wash cycle begins. It fills up fine but starts and stops/pauses and the time doesn’t lapse. On a normal load...
You have a Series 10 machine 1st two digits of your s/n.
Seems like you have the Service Manual or troubleshooting guide.....can't get that from Servicematters any more I feel you have some drive system binding.
I helped a owner on another forum similar problem. Google this "Neptune TL Spinning Issue Will Not Proceed". Did a lot of up front testing in the end he ended up replaceing the Outer Tub Bearings, the Clutch Pulley.
Start by opening the washer lid and see if you can rotate the wash basket with one finger in the CCW Spin direction. There should be only slight resistance to rotate the wash basket CCW. During the 1st water fill of the wash basket the Control Board will spin the wash Basket slow rpm you can enter Service Mode and observe the rpm on the LED console.
Next start a Quick Spin test and note the highest RPM range the machine will spin up to. Looking for Outer Tub Bearing resistance.
I would suggest another DIY forum to work thru this issue if you are going to DIY. This forum is hit and miss we posting pics and e-mail notification for support......Rich
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
My Washing Machine fills and drains at the same time, what can i do? I have just about the same problem. We had put in a new drain line for my washer. This new line has been on for over a month W/O any...
Yes, it is a siphon problem.
Check the hose where it goes through the wall. It may be pinched and cutting off air.
If air cannot enter the hose it will siphon. If the hose is too low it will siphon.
May 23, 2009 | GE Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Normal wash cycle- tub fills (?), then comes a loud hummmm and nothing happens. I noticed water level didn't reach heater coil and added water until limiter switch clicked. Still just a loud hummmm....
You are an expert enough reading this. But with a terrible complicated dishwasher. First clear the waterlevel problem.
Rest is a result. You do not need me, join us. Next time buy something more plain.
Apr 16, 2009 | Dishwashers
Thanks!! My estate washer sometimes will fill, most of the time not. I have found if I set it to rinse It starts the 1st cycle and fills the tank, but, after that I have to fill the tank with a garden hose...
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Mar 09, 2009 | Washing Machines
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
281 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
