Question about Dryers
Dryer do breakers go bad. my house is 25 years old. it is a220 breaker for my dryer
    President:
  • 1,136 Answers
Yes they can go bad. Is your dryer working at all?
Vic
Posted on May 17, 2009
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Dryer run not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 14, 2008 | KitchenAid KHGV01RSS Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
My Roper Electric Dryer will not heat
Heating element
Thermal fuse
Wiring
Mar 07, 2008 | Roper REX3614KW Electric Dryer
Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Apr 08, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
