Question about Garmin nuvi 750 GPS Receiver
Garmin750 usb'd to PC. all i get is log with connect pic
Just out the box, garmin 750..plugged into my pc and turned on.
said 'searching for maps' and now all i have on the screen is the garmin log and a pic of a garmin connected to a pc
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Ummmmm Ocean_1.... why bother to post when you just repeat what I already posted.
  • SHARCNET-USA
    That is because its in data mode. Whenever you connect it to your PC, it goes into data mode. Data mode is the mode where you can transfer pictures & music to your GPS from your PC.
    You can also update the firmare as well. Data mode is not the normal operating mode. If you remove the plug from the GPS, it should go back to GPS mode. However, ALWAYS make sure you SAFELY REMOVE the device in windows BEFORE removing the plug!!! Otherwise you could risk damaging the system operating files!
    - Jim
    SHARCNET-USA
  • 14 Answers
When you connect the 750 to a computer it goes into data mode and the screen shows only the connected to PC icon. Let it charge for a few hours and then disconnect it from your computer and it will come up in Navigation mode,
Posted on Jun 18, 2009
No map info on nuvi 205w
Plug your nuvi into your PC. Go to the Garmin.com website and log into your account to see your map information. You can go to your account and see the map downloads and reinstall it from there. Or you can download their software "Garmin Express" on your PC. Run the software while your Garmin is plugged into your PC and it will check for any updates for you.
Mar 04, 2015 | Garmin nuvi 205W GPS Receiver
How to upload map from computer to sd card for Nuvi 1310
1.connect your device to pc via USB
2.it will open as GARMIN mass storage on your pc
3.open GARMIN drive from my computer
4.if windows 7, look left side Organize->Folder and search option
5.click View Tab ->click show hidden files folders
6.uncheck hide protected operating system file.
7.click ok
8.open .system folder and delete gmapprom.img and paste your india map file and rename it to gmapprom.img
9.copy JCV and SID folder to GARMIN main folder as shown in the image.
thats all
Feb 23, 2014 | GPS
My computer windows XP can't see/recognize my garmin nuvi 1250. I just bought it .The garmin was made in Taiwan. I have intention to upgrade the map.. coz it is old map (2010).but I cannot register...
Assuming the Garmin communicator plug-in has been installed in the Internet Browser and registered at Garmin.com with a user account - the Garmin goes into (PC) communication mode when its connected to the USB port of a PC.
If that doesn't happen - i'd suspect the USB cable first.
Assuming the cable is ok - including the USB port of the PC - the Garmin must go into (PC) communication mode. If not the Garmin USB jack could be defective.
Jul 01, 2011 | GPS
Garmin 1300 stuck on maps loading frozen I have a GARMIN nuvi 1300, running off a car cigarette lighter type charger, it was working fine for weeks, I got in the car, started it up and the nuvi is STUCK on...
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
Apr 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 255w trying to register and update maps. Got the Firefox addon-loaded successfully, restarted firefox; plugged in usb cable to pc and GPS; can not find my device. Tried XP sp3 desktop and vista...
The problem was following the Garmin instructions too closely. What I found via a GPS forum was that some USB cables can be finicky and trying different USB cables may solve the problem. In my case I found I had to turn the nuvi 255W on normally during registration; then connect the USB cable to device and PC. Then the registration and download worked.
The documentation is not clear on this.
Found I had the latest map; but did upgrade my firmware from 5.90 to 6.10.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
How do I update my Garmin 750
You mainly use a usb and internet connected computer to updatethe map chip.
Dec 12, 2009 | Garmin Nuvi 750 Car GPS Receiver
Turn my gps on and just says garmin with a pc logo? Turned it on and off and still same thing.
garmin with a PC logo indicates that you have hooked the unit through USB to a PC. It also appears if you try to charge it with AC Chrager. If the cable is not connected and still you are getting this logo, it is malfunctioning. have it serviced by Garmin.
Nov 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin 750 cant unlock maps
Map unlock codes are specific to each unit. You will need to contact Garmin to obtain a code to unlock the maps.
Jul 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Error message
Install the Garmin City Navigator Cd to your pc and then connect ur garmin to ur pc with the USB cable.
You might have to unlock the maps with information provided with ur garmin like ur unit ID and ur unlock code.
Another possiblity is that ur memory card is gotten corrupted so try installing it on a different micro sd card.
Let us know if u have any luck.
Oct 03, 2008 | Garmin StreetPilot i3 GPS Receiver
I need to register my new garmin750 need a phone number, not having any luck on line
Hello llmahoney,
To register your Garmin GPS product simply go to the Garmin website at https://my.garmin.com/mygarmin/marketing/register.htm. If you need to call Garmin support for any reason, their number is 1-800-800-1020 (U.S.).
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | GPS
Garmin nuvi 750 GPS Receiver Logo
174 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
