Question about Toshiba CF19G22 19" TV
Loss of vertical deflection,only a horizontal line
The vertical output ic and the current limiting resistor in series with the fast recovery diode was changed ,having been tested as defective;still no full screen deflection.i was unable to confirm the presence of a vertical drive signal at the input of the vertical output ic.
2 Suggested Answers
bihug
  • 15 Answers
SOURCE: unit has sound, no vertical deflection. caps and
If there's an audio,,it might be the defective Vertical IC...but check first if there's 24v-26vdc supply coming from FBT going to Vcc of Vertical IC.
If there's no Audio,and only white horizontal line in the screen,check the Vertical out of Jungle IC.
Posted on May 03, 2010
Testimonial: "great information, very helpful."
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
On screen horazantal white line
May not be an easy fix:
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke
May 27, 2014 | Samsung Televison & Video
Horizontal ine in CRT tv
Failure of the horzontal linerity coil, possible dry soldering on the board of the components- resistors and capcitors- in the horizontal coil circuit . Also failure of the deflection coil- YOKE- in the crt. So check the coils and the circuit around this section as the rest of circuit seems OK.
Apr 06, 2011 | Televison & Video
32 inch tv worked. after transport 8 hrs, there is no picture, just a flat horizontal line in center of screen. is this a bad picture tube? what else might it be?
Hi:
There could of been a connection in the vertical circuit that has come loose during transport, another thing is i hope did not use a dolly underneath to load and unload this unit as they tend to crack the main board in and around the deflection circuit. A straight line means there is no vertical deflection for the CRT, if you look inside the vertical output wires going to the yoke on the neck are usually yellow and white check this connector to see if it just poped loose while transporting.
Aug 24, 2010 | Philips Magnavox 27MS343S 27" TV
Have a 29 inch 5 or 6 yr old rca color tv lately we get a colored horizontal bar across the top of the screen and the other day we have fuzzy black lines across the entire screen
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
May 30, 2010 | Televison & Video
The picture went out. Still have sound.
Good luck..
May 23, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
TV has a line across middle from left to right
It depends what part was damaged in Horizontal section. Here in Philippines labor costs for this size of TV is ranging from $50 to $150.
Feb 27, 2010 | Televison & Video
Just a straight line instead of a picture
A straight horizontal line across the screen means you have no vertical deflection. Could be as minor as a bad solder joint, a failed capacitor, or the vertical deflection IC is bad. Or shorted diode, burnt resistor....
Jul 14, 2009 | Televison & Video
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
Mar 23, 2009 | Sony KP-46V35 TV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Televison & Video Logo
192 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
