Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE4 dryer trips circuit breaker and when we flip the breaker back on, it displays a PF code.
  • 330 Answers
SOURCE: HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Posted on Jul 06, 2008
canbruce75
  • 1776 Answers
SOURCE: Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Posted on Sep 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Posted on Oct 03, 2010
kevster6720
  • 171 Answers
SOURCE: circuit breaker tripped, i reset it and the dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Posted on Oct 07, 2010
I have Kenmore elite oasis electric dryer when you push start button it goes to pf code ive tryed holding down start button & it just flashes & is back to pf code how do I reset it ?
try unplugging it from power or tripping the circuit breaker(which might be easier). then re energize it and see if it resets. good luck.
Jul 29, 2016 | Kenmore Dryers
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
We just replaced the power cord and outlet for a Kenmore Elite HE3 dryer and now it will not go on. I flipped the circuit breaker on and it said PF and now I get nothing.
PF error = Power Failure - error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Here is a site to double check the wiring:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Good Luck Tim
Nov 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Digital display
PF means Power Failure. Check the breaker in your breaker box. The dryer uses 2 breakers that are put together. Reset the breakers to see if the problem gets fixed.
May 13, 2010 | Kenmore Elite HE4 Electric Dryer
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Code "PF" = N/A
Soft Touch -PF- means power failure, nothing else. Most likely the problem is not with the dryer. The circuit breaker became too weak for the dryer load. I beleive replacing the circuit breaker will solve the problem. Gendos...post back
Feb 25, 2007 | Whirlpool GEW9250 Electric Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
249 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
