Question about Zenith B27A11Z 27" TV
If t.v was unplugged do i need to get a code to reset t.v.? just bought it used
How do i get the channels to work on the t.v as it is all snow. i bought this used and it suppose to work and the guy thought even though it was unplugged it should still work. will i need to find a code or something. not real electronically smart
Im having problems with my iview 780ptv cant see or hear anything just snow we try something of reset but I think we did it wrong but now it show pure snow
Snow means the TV isn't getting any signal from the channel. Try doing a channel search in the settings. Or, if you're typing in a channel, put .1 at the end of it. Like instead of going to channel 3, go to channel 3.1.
Feb 02, 2015 | Cell Phones
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
I only get channels 2 through 22, 23 on up - nothing
this is not a problem from remote control. You must adjut the TV program go to the MENu, run the scanner, for add the program TV.Try to reach you supplier TV cable for explain then, if there are not problem witht the receiver box.
however if you need to reset the code program go for free download:
www.fitness.manualsonline.com or www .remotecodelist.com
sincerely. God bless you
May 07, 2012 | Televison & Video
Model ewt1321 emerson tv stuck on channel22 so direct tv will not work snow only
with the set turned off --unplug it for a few minutes and plug back in which may allow it to reset itself
Mar 23, 2012 | Emerson SpongeBob SquarePants TV
Reset code for channel access
What's the model on the TV? Can try to look for the manual online. Might be worth a shot to try a capacitive discharge (unplug power, try to turn tv on a couple of times while power is unplugged, plug back in and try again). That may reset it.
Can also try going in the menus and rescanning for channels.
Apr 06, 2009 | Philips Televison & Video
Locked out TV channels
Need a make and model to determine what codes needed to unlock.
Jan 19, 2008 | Televison & Video
Sharp 36K-S400
Check the tuner input mode it has (air, cable,hrc,irc) with new stations updating to HDTV the demodulation at the tv sometimes looses the color burst sync. I have seen this with more and more tv's with pip tuners , it resets to the default of air ( rabbit ears ) at 75ohms and the low band snow, when you go to the high band (56+) it finds the color sync and resets the vestigial sideband offset, it happens more often if the SAP or CC is also trying to aquire the proper offset. good luck.
Nov 17, 2007 | Sharp 36K-S400 36" TV
Symphonic SC3919
most likely your channels are in SAP mode, you need to set them up as stereo via the menu. Remote code should be 044. For VCR. turn TV to channel 2 or 3 then press VCR button
Sep 11, 2007 | Symphonic SC3913 13 in. Combo
Help! How can you unlock a pin on a TV that you don't know?
Tried unplugging it for five minutes then plugging it back in? It resets the software.
Sep 09, 2007 | JVC AV-27020 TV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith B27A11Z 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
