Question about Refrigerators
Water leaking into the refrigerator
We have a Sears Kenmore upright refrigerator (freezer on top) model # 105.70967990, ser. # EJ412042, mfg. in 10-99 that has recently started intermittently collecting water in the left vegetable drawer and on the bottom of the refrigerator; it's happened twice in the last two weeks---one time the water was so high that it came out the door onto the floor. The refrigerator has an icemaker but it is not hooked up to a water supply. Any suggestions? Jim
    President:
  • 1,136 Answers
Hi, You have a drain plugged in the frezer. Your model # doesn't come up but what you need to do is remove the rear anel in the freezer and clear the ice. If the floor of the freezer has two screws holding it, remove it as well.
Please check the model# again and I can assist you further. There is an after market deat transfer strip you might need to add to prevent this from reaccuring.
Thanks
Vic
Posted on May 17, 2009
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
Why freezer doesnt turn on
If it is a frost free model, the defrost timer could be stalled in defrost. Other than that the thermostat could be the problem.
Jul 16, 2014 | Kenmore Refrigerator Freezer Shelf 13 5/8...
Kenmore freezer upright model 253
Refer this inquiry to Sears.
Oct 22, 2013 | Refrigerators
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore model 10677062791 and the electro solenoid water valve is bad. the part is about 40 dollars and a whole new icemaker is about fifty dollars. there isnt a sears around these parts but lowes...
Click here to go to Sears website. I have searched for this valve and found it to be about $38. Is this what you wish to know?
If you are unsatisfied, please post a comment before rating this solution.
Oct 27, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
Model 106-74269401 mfg date 6/05. Constant pool of water on interior top shelf leaking from freezer above. What is standard repair?
That is most likely the defrost condensate pan inside the freezer has frozen over and closed the drain opening. Once that happens then the water has no where to go but the freezer or the fresh food compartment. Below is a link to different ways of this happening. Just choose the section that resembles your refrigerators problem. The water freezing over does not always need to go to the extreme measure to prevent it. It's possibly something blocking the line between the freezer and the pan under the refrigerator. Let me know what you find, Thanks, Sea Breeze
click on link
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 19, 2009 | Kenmore Refrigerators
Water leaking into refrigerator
yes you have to take off the ice maker then remove the scews, sometimes there is a air channel that has to be removed which are held in by plastic tabs
May 06, 2009 | Kenmore 64802 Top Freezer Refrigerator
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support...
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
