Question about Dell A960 All-In-One InkJet Printer
PAPER JAM BUT NO PAPER
A960 PRINTER HAS PAPER JAM BUT UPON DISASSEMBLY I FOUND A PART OF THE PRINTER WAS THE JAM. NOW THIS PART IS DESCRIBED AS FOLLOWS ONE SIDE HAS BROWN PAPER AND THE OTHER SIDE HAS A SILVER MATERIAL AND SANDWICHED BETWEEN IS A LIGHT TRANSFERABLE MATERIAL .THE PARTS PHYSICAL SIZE 1 1/4" W X 2" L X 1/4" H I HOPE YOU CAN HELP ME .FIND THE CORRECT LOCATION FOR THIS PART.
THANK YOU
BRUCE E. RIEGEL
RIEGELTORO@YAHOO.COM
  • BRUCEERIEGEL Oct 18, 2007
    THANK YOU FOR YOUR TIME BUT THIS WAS A PROBLEM THAT YOU COULD NOT HAVE FIXED DUE TO THE FACT THAT FIRST IT WAS NOT A PART OF THE PRINTER.
    I ASKED MY FAMILY IF THEY HAD EVER SEEN THIS OBJECT BEFORE AND MY DAUGHTER SAID YES I KNOW WHAT THAT IS SHE SAID IT WAS A PACK OF MYLAR FILM SHE USES AT WORK . IT MUST HAVE FALLEN IN THE PAPER FEED. AMD CAUSED THE PAPER JAM . THANK YOU
  • 691 Answers
Could this the cork pad off the paper sheet feeder? Look toward the bottom right of the area you stack the paper in. If there is a recess about the same size as the part you have in your hand, then this is the answer.
If it is the cork pad, you can simply glue it back in place.
Any chance you could post a small photo of the item on here?
Posted on Oct 17, 2007
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
Paper goes in sidewides and gets stuck when it trys to print
Sometimes you need to clean the rollers that pull the paper through the printer. There could be a piece of paper torn off stuck back there that causes any paper going through to jam.
Also, make sure the paper sits tightly in the feeder tray but not so tight that it bows.
Apr 13, 2011 | Dell A960 All-In-One InkJet Printer
Paper jam
Ohh Paper jam, so you open the printer front cover or Tonner catridge or ribbon catridge. then smothly remove the paper. its depend upon the printer.
Thanks
Aug 15, 2009 | Office Equipment & Supplies
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
My dell 960 wont feed paper and keeps giving me a message there is a paper jam... but I don't see any paper
Its a Hardware problme with the Printer..Printer needs to be get repaired or needs to be replaced
Feb 28, 2009 | Dell A960 All-In-One InkJet Printer
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Printer jam
Sounds like something is stuck in the track. Try taking the cover pieces off and looking for something lodged in there.
Jun 10, 2006 | Dell A960 All-In-One InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
