Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Audio problem on my direct tv
How can i adjust my tv so the background music and dynamics do not overshadow the dialog
    President:
  • Philips Master
  • 1,779 Answers
Take it out of surround sound mode, some have enhanced sound in the audio portion of your menu. Put it to stereo.
Posted on May 17, 2009
Is there a fix for poor audio quality on KDL 46ex500?
Do a factory reset to this set, and check. If it do not help you, check its speaker/s. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 21, 2015 | Sony KDL-46EX500 46" Bravia EX500 Series...
Background noise and music is so loud we can't understand the dialog
If the sound was disconnected, you would hear absolutely nothing at all. There is a problem with the sound signal itself, so connecting external speakers probably would not help at all. Electronic components have failed, which caused the sound problem issue.
Aug 05, 2014 | Sceptre Televison & Video
Vsx-52o when watching dts or any good movie the low sound talking you cannot hear well unless the sound level up to 55 or more ,but when the action or music starts it blows your head off its that loud...
That could be one or both of two things at work here.
One is a failing or mis-configured center channel. Crack the manual and make sure the speakers are all workign at the desired level with test tones.
The other is dynamic range (ratio of loud to quiet sounds). In a silent listening environment with the volume set at a comfortable level for the loudest sounds (like during the beginning of some movies you get that THX sound logo or some other audible but loud musical intro, THAT's what you adjust for) the relatively quieter moments would still be audible. Add normal background level sounds of a real-life environment and you can lose the quieter sounds and dialog.
In a perfect world and in accordance with the engineer's decisions, the widest dynamic range is the correct way to enjoy a given recording or movie.
http://en.wikipedia.org/wiki/Dynamic_range
Experiment with the DRC (page 34) for each soundtrack to see if compression might work better.
Jul 18, 2011 | Pioneer VSX520 Receiver
Background sound often is so loud it drowns out conversations. Often occurs w=in a movie when there is some background music and dialog. Cannot hear the dialog. Has occurred when watching live music. ...
Looks like you have inadvertently enabled some sound effect, usually these effects can be enabled/ disabled form sounds menu. They will have names like surround, movie hall, concert etc. Go to the sound settings and disable any activated audio effects.
Mar 14, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
I have background sound on my TEAC HTX1800 DVD player, but I can't hear the people talking. Please help?! Regards /Hester
Chances are you are playing movies coded for Dolby Digital Surround. Depending on what kind of receiver your DVD player is plugged into, the receiver may not have the Center channel operating or turned up. Most all dialog comes from the center channel of a surround sound system. The receiver usually has a separate output for a center channel speaker, and a separate volume control as well. This will adjust the dialog volume up.
If you are not using a receiver, or plugged directly into the TV, check the audio settings on the TV. They may not be set up for the surround, hence why you are missing the dialog. Good Luck
Feb 21, 2011 | Audio Players & Recorders
DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Aug 24, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Secondary audio drowns out primary audio
if you are using a surround sound receiver for your audio, you need to change the surround mode. i like mine set up for dolby pro logic. there are many different settings on the new recievers so experiment until you find one that you like.
if your sound comes only through the tv, use the audio menu and set it to stereo, although with some brands "surround" will get rid of this problem
Jan 20, 2009 | Televison & Video
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
May 30, 2008 | JVC AV-32260 32" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
