Question about Kenmore Dishwashers
My dishwasher wont drain out? any ideas? - Kenmore Dishwashers
  • Kenmore Master
  • 19,396 Answers
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 17, 2009
Bosch dishwasher
,ake sure when it was installed the hose is not higher than the discharge drain, it will create a vacuum and it wont drain for airlock, that's all.
Jan 28, 2014 | Bosch Dishwashers
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 12, 2010 | GE Dishwashers
It washes the dishes but the water wont go away i have cleaned the filter and surrounding area but water wont go away any ideas please thanks
heatman101
Sep 05, 2010 | Indesit Dishwashers
DW5700P1 dishwasher must have stopped running last
A lot depends on at what point the dishwasher stopped working.
Have you tried to turn the mains power off and on again and then try one of the short cycles.
I would suggest if water is not draining, then empty with a small pan and check filter for blockages. Also good idea to check there is no blockage on the drain side.
A good site to check is
Please post a comment to let me know what you find.
May 29, 2010 | Frigidaire Dishwashers
It wont drain
Your dishwasher may have food or lime/calcium buildup trapped inside it that may prevent it from draining properly, it could have a kink in its hose, or it may need a new part.
Here is a bit of about how the dishwasher types actually work, to give you a better idea of what you're dealing with and how to go about finding a solution to the problem:
The first thing you must do is figure out what style of D/W you have and a little of how it works so you can have a better understanding of what to look for. There are two basic designs, the direct drive dishwasher and the forward-reversing dishwashers. Direct drive dishwashers do not have to stop to drain the water will forward-reversing dishwashers The first thing you must do is figure out what style of d/w you have and a little of how it works so you can have a better understanding of what to look for. There are two basic designs, the direct drive dishwasher and the forward-reversing dishwashers. Direct drives dishwashers do not have to stop to drain the water will forward-reversing dishwashers have to stop the motor and start it up in the other direction to drain the water.
Thank you for contacting www.Fixya.com
Jul 27, 2009 | Kenmore Dishwashers
Dishwaher wont drain-checked drain hose and its clean
The problem is most likely the drain valve. It is electrically operated and with your problem it is the most common cause.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Kenmore 16719 Dishwasher
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Dishwashers Logo
404 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
