Picture goes of but with audio
25 sony tv intermitent chasis shutdown
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
Posted on May 31, 2008
Sound comes and goes constantly on a sony tv model KP60XBR800
About 27,600,000 results (1.16 seconds) Search Results
    Sony TV sound issues - Forums - CNET
    www.cnet.com > Forums > Sony
    CNETJun 11, 2015 - I have a Sony Bravia KDL52V5100 LCD TV & after only having since May 2009, I am now having sound ... I'm going to purchase a new HDMI cable to see if that might solve the sound cutting out problem. ... Has anybody come across problems like these 2? .... Sony is and always has been one of the best TV's on the market. Netflix app on Samsung Smart TV audio dropping out
    Jun 11, 2015
    sony bravia automatically turning off and on
    Jul 7, 2012
    Clicking noise after powering off sony kdl-40v3000 lcd hdtv ...
    Oct 25, 2007
    More results from www.cnet.com
    A loud humming or buzzing noise is coming from ... - SONY
Jan 05, 2016 | Sony Televison & Video
Tv gos off turn on it gos right off will not stay on r52WH74
the trouble with the tca itc 222 chasis is that there is about 25 different resons that what you describe called a shutdown condition will occur. The first thing to know is that its not a main fuse problem.. the processor is recieving power and is detectecting a condition that is causing it to shutdown for safety. The top reason for this shutdown include a shorted Horizontal Output transistor, A bad flyback transformer. There has been reports of bad capacitors cp150, Technicians have special computer equipment that they plug in to read "error codes" that can help determine the problem. unfortunatly unless your a techniction these sets can be trouble to work on. I work on these daily and still they are trouble
Apr 23, 2009 | RCA R52WH73 Projection Television
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Problem with tv turning on and off
Does the green light begin to flash when the picture disappears? If so, you have a weak lamp causing your TV to shutdown the picture. Replace the lamp with an original Sony lamp as the aftermarket lamps are known to have problems such as early failure and low brightness. Please be sure to rate this solution. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony 36XBR800 Standby light flashes ...no picture sound
For 6 blinks,Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
I think this will help you to solve the issue.
Dont forget to Rate!!
Good Luck
Dals123
Apr 10, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
ABL protection active & color's spots
Replace the capacitor and the resistor as well as the diode that feeds the b+ to the vertical IC.
Sep 28, 2006 | Sony KV-32V26 32" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
