Question about Dryers
Maytag dryer won't turn on
My maytag dryer will not turn on . the breaker is not tripped so i'm assuming that there is juice aytag model#MED5600TQ0
  • howe125 May 17, 2009
    i don't have any kind of meter to check continuity
    President:
  • 1,136 Answers
Hi, The first thing to check is the thermal safety located in the back. UNPLUG the dryer. emove the rear panel and locate the fuse on the blower housing middle left. It is white and in 1/4" wide and 3" long with twowire going to it. You can test continuity to it. If it has continuity, it is ok. This is
the most common problem. If II can assist you further, please let me know.
Thanks
Vic
Posted on May 17, 2009
  • Victor
    Victor May 17, 2009
    Ok, You can tape the two wire together and try it that way. It is only temporary..not safe for regular use thaat way. Let me know please.
    Vic
What will cause my maytag dryer to throw the breaker when i try to start it
Not a dryer pro but if the dryer is on a circuit that's already loaded up, or is overloading your current one (amps wise) that could cause it, and especially if the breaker is weak. Could be shorted capacitor or drive motor, or heating coil short situation. (wire melts, ends up shorting against housing). If the breaker checks out, suspect the heater element next, motor last, I'd say. Good luck. Maytag Dryer Trips Breaker
Mar 15, 2015 | Maytag Dryers
What year was MED5600TQ0 Maytag electric dryer produced?
Check the date code on your unit against the chart below to get the mfg date. Maytag Date Codes The breakdown for Maytag Serial Numbers is:
1st Alpha Character (9th position) = Year Manufactured
2nd Alpha Character (10th position) = Month Manufactured
or go here: Maytag Date Codes
Nov 05, 2014 | Maytag MED5600TQ Electric Dryer
Aytag ensignia dryer model # is MDE7657BYW
Go for item 5 on this diagram. You can buy it off appliancepartspros.com
Parts for Maytag MDE7657BYW Control Panel Parts
Aug 24, 2014 | Maytag Dryers
Maytag dryer wont turn off
I thank you need a new Timer part# 3979617
Jan 21, 2013 | Maytag Dryers
Maytag model #med5600TQ0
There is a period of a few milliseconds where you can throw in a leftover sock or two but after that the open door safety shutdown takes effect.
Jan 05, 2018 | Dryers
MY MAYTAG MDE9700AYW WILL NOT TURN ON
Are you getting power at the console? Also, check to see if one of the breakers has not tripped. Dryer runs on 220v and you may have tripped one breaker that will show power to the unit but won't let it start.
Dec 24, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Electric dryer trips circuit breaker after about 5 min when running at high heat not sure of model number
Most likely culprits are the thermostat (or a short in the wiring related to the thermostat) . I am assuming it is a normal current breaker and not an earth leakage breaker. It seems likely to be the thermostat as that probably switches after a few minutes (whereas the element which is also a common failure is on from the start of the cycle, so if there was short in the element that would take the breaker out immediately).
Does it do the same whatever heat setting you select?
If you switch it back on before letting it cool to much does it trip sooner?
If the time it takes to trip changes when you change the heat setting that would point to the thermostat/wiring too.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 15, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Feb 28, 2009 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryers Logo
316 people viewed this question
Top Dryers Experts
