Question about HP PSC 1315 All-In-One InkJet Printer
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
Hp 1350 all-in-one printer. I get a message saying there is a paper jam or misfeed, but I can not find anything that's jammed in the printer. paper goes in half way then stops.
  • Anonymous May 17, 2009
    I have had the same problem in the last couple of days. The paper stopped half way, then there was a message said papaer jam. I have tried several ways: 1). remove the paper, 2). turn off the power and restart the computer 3). re-install the software. But the problem is still there. It is very weired.
    Sergeant:
    Champion:
  • 240 Answers
Try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
Posted on May 17, 2009
My HP psc 1350 all in one printer scanner copier keeps saying paper jam, how do I clear status on my computer when I have fixed all paper jams and printer says clear?
I suggest you uninstall the printer and disconnect it from the mains and from the computer. Restart your computer a couple of times and then reinstall the printer.
I have used HP printers quite a bit and find them reliable if they are left alone but if I try and interrupt their work by cancelling a print once it has begun or even by attempting to continue working on the computer while it is printing it starts acting like a crazy person and won't stop until it has been switched off for about half an hour. All my HP printers have been the same in this respect...
Jun 13, 2016 | HP Psc 1350 All In One Printer Scanner...
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
Printer paper pulled half through then stops
Leading cause of paper jams or misfeeds is debris or foreign objects that fell accidentally in the paper feed area. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any obstructions.
Also, try to open the printer cover and make sure the paper path is free from foreign objects or debris.
Re-insert your cartridges and make sure they are properly seated in the carrier.
Dec 23, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
HP PSC 1510 keeps coming up with a misfeed
There may be a very small jam in the printer. Also, test with a different **** of paper. Put in one sheet to test.
Jun 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP 1350 Says theres a paper jam and won't clear. All lights on.
Try unplugging the printer from power, (Turned off of course) Wait 5 minutes, plug the printer back in. Now open the case like you're going to clear a paper jam, or change ink cartridges. Close the case. Press the Power On button of the printer.
Jun 05, 2009 | HP PSC 1350 All-In-One Thermal Printer
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
Nov 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1315 All-In-One InkJet Printer Logo
555 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
