Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold gd5rhaxnq00
What can cause air return to freeze? i checked door seal
  • 3,267 Answers
Couple of reasons
a) Excess humidity in the refrigerator due uncovered food items.
B) freezer door not closing fully( look for any visible damage or hardness of the seal. The seal is made of multiple layers so even a few cracked edges will cause leakage.
c) the returning air if not circulated properly by blower which also gas a heating coil for humidification could have failed causing formation of ice.................sodeep
Posted on May 17, 2009
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Gd5rhaxnq00
The lights are controlled by door switches and a small circuit board near the compressor=> W10135090 Main Control Board
The control board is quite expensive and if you know someone that can replace circuit board parts it would really pay to have them replace a defective relay, Thanks Sea Breeze
Jan 30, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light will not come on model#gd5rhaxnq00
Unplug your refrigerator and pry out the door switch and check for continuity. In most cases this can be a defective door switch. Can you test the door switch with an OHM Meter?=> 1118894 Door Switch I am here should you have questions or comments, Thanks Sea Breeze
Jan 10, 2013 | Whirlpool Refrigerators
Apartment size refrigerator just started to freeze everything
Check the seal around the door itself this may be worn or detatched. This will cause warm air to get into the appliance and freeze inside thus making you freezer look the the arctic.
Mar 12, 2010 | Whirlpool Refrigerators
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Refrigerator not cooling, only fan is running.Compressor is hot to the touch. Frost accumulating in freezer and on produce drawer temp controls
Somewhere air is getting past the door seal. The door may not be closing all the way. Frost cannot accumulate without a source of water. It comes in the air thats getting in past the seal. Check the drawers to be sure they are all the way in. Check anything that may be sticking out that may prevent the door from closing all the way. Check the door seal for damage and replace the seal if any significant damage is found. Good luck
Dec 13, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Gold GD5RHAXNQ00 refrigerator not cooling properly.
It takes time for the temp to adjust(up to 24hrs) If the door is open a lot(looking into the box) or the door gasket is bad this will contribute to your problem. Are you sure the thermometer is good that you are checking the machine with. The thermistor could be bad as well(the control that senses the actual temp
Nov 03, 2009 | Refrigerators
Ice maker not getting water, but water to the door dispensor ok
The fill solenoid for the ice maker is not working. Replace it and you are good to go.
Sep 24, 2017 | Whirlpool GD5SHAX Side by Side...
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
307 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
