Question about Gateway GT4010 (RBGT4010) PC Desktop
NO POWER GT4010 GATEWAY COMPUTER. THE POWER BUTTON WOULD NOT START THE COMP. REPLACED THE POWER SUPPLY AND STILL NO POWER. BUT MY INTERNET IS CONNETED THRU THIS COMP. AND IT STILL WORKS.
  • 818 Answers
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
Posted on May 17, 2009
When I turned my computer on most times the switch wouldn't start the computer I replaced the switch no power I'm thinking it's the power supply
CABEL8X1. NEED TO NO MOORE TO HELP.INFORMATION IS IMPORTENT.1 IS THERE FANS MOVING. 2 ANY LIGHTS ON THE MOTHERBOARD.
Apr 04, 2013 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Bad motherboard or power supply which fries motherboard
Gateway hasn't had any recalls on it that I know of. maybe it is not the mother board. It might be the hard drive. Hard drives can do that aswell. When I fix a computer the first thing I check is the hard drive. A little bit of advice with computers. Start with the small things first and work Your way up to the big stuff. Hope that helps.
May 20, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 power up
your problem sounds like its the power supply, a bad power supply will some times power the fans but the voltage isnt right to power the pc. you can get a tester for around $15 at a place like radio shack
Sep 06, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Hey man hows it going
Have you test the power supply for voltage, Is it good, if it is then the problem of course is not power supply. Some power supplies have a light on them. Also does the power supply fan work, If not almost always sure sign power supply is gone. Old power supplies are still available Every time I junk a computer P4 or older I save to power supply, What wattage?
Jul 10, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
My gateway GT4010
check the power plug first and see if it is properly plug in and turning on the power button, if does not work, get a new power plug and try as i've said again and if does not work the power system has problem and should be changed.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
She won't run
do you still have your restore CD? try to fresh restore it and updates everything on that unit again. Often online gamers send you malicious script that crashes your system.
Aug 04, 2007 | Gateway GT4022 PC Desktop
Gateway GT4010 (RBGT4010) PC Desktop Logo
407 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
