MICROSOFT WIRELESS MULTIMEDIA KEYBOARD 1.1 > not working
Hi
I have the MICROSOFT WIRELESS MULTIMEDIA KEYBOARD 1.1 also Optical wireless mouse .
I have setup both of them and installed the drivers given by Microsoft CRROM,
I am on Windows Enterprise 2003 server.
Mouse driver >IP55.exe
Key baird Driver  > ITP55_32Eng.exe
Mouse worked successfully burt Key board did not work.
Reciever  have has 2 lights blinking .
Can anyone help me to resolve this issue.
Thanks
Reddy
  • 6 more comments
  • Anonymous Nov 12, 2007
    I replaced the batteries in my wireless keyboard at my office and now it will not work. The mouse works
  • baboos Mar 26, 2008
    iam using microsoft wirless keyboard, and mouse, both are not working properly, especially keyboards, short cut buttons, not working, now l ilost my software for these things, so how can i get the software, i tried in google, but i cant see proper link for to install this software, please help me to find out the driver from the site...
  • intro May 29, 2008
    I have been using w/o problems the Microsoft Wireless Multimedia Keyboard 1.1 for 1.5 yrs. Today, I used it in the morning and when I came home the mouse is working, but the keyboard keys are not working properly. No letter keys work; the number keys are reversed (1 is 9, 2 is 8, 3 is 7 etc. weather on the 10 key or keyboard row. The "0" key on the 10 key is z; and the "0" key on the number row performs a return.) The space bar is the Num lock key; the back space key is *, the left arrow key is [ ; the right arrow key is ]; the up arrow key is -; the down arrow key is =; the tab key is /; the enter key on the 10 key is 0; the enter key on the main keyboard is +; there are a few other keys that perform other functions that they are not supposed to be doing. The only key that does what is supposed to do is the Start Key. It does bring up the start menu. I have rebooted several times. I have down loaded new drivers, I have changed USB ports, nothing fixes the problem. What is peculiar is the mouse still works. Fortunately the keyboard on my lap top works, but I did not purchase a wireless keyboard to use the computers keyboard. Can you offer any assistance?
  • Anonymous Oct 27, 2008
    its the same but i have a xp
  • smith_carrol Dec 07, 2008
    I relocated from CA to GA and once I got unpacked I tried to use my wireless keyboard and it would not work. I changed the batteries and still nothing.
    HELP!!
  • Anonymous Jan 26, 2009
    keyboard doesn't respond, mouse does.
  • kitellecat Mar 21, 2009
    My Msft wireless keyboard 1.1 is malfunctioning, too!
    The backspace key = 8
    1 = n; 2 = m; 3 = [; 4 = =;
    The space bar = 6!!! It's totallly wrong!
    How can I fix this? I've already changed the batteries,
    so it's not that.
    Thanks -
    kitellecat@yahoo.com
  • brownCME Apr 27, 2009
    I am writitng from my laptop because my desktop is completely disabled due to a malfunctioning wireless keyboard. I have changed all the batteries and cannot find the software disc.Any suggestions?
I was just about to write "I have the same problem", but i think i fixed it!!!!
background: I move my wireless keybd/mouse between my desktop and laptop units.... All was fine until a few days ago when some update completely disabled my desktop... I think the wireless began malfunctioning about the same time.
Just now, I pressed the ?reconnect button? on the front of the keybd/mouse receiver then pressed the connect buttons on the back of each device and PRESTO!! the keybrd works!!!
I just typed this entire message with the wireless keybd.
I hope this helps someone
Posted on May 12, 2009
Well i'm using the exact type of keyboard and i also have the same problem as well......especially when i exchange battery. The best way to fix it is to press the connect buttom on the back of key board and press the buttom on the reciever. Also if u want to increase success rate is to bring the reciever and the keyboard extremly close, almost attach back to back, then type both buttom at the same time :)
Posted on May 25, 2009
I had the same problem and was very frustrated. I don't know if I ever had an installation CD. I am so happy I found this website, because solution #4 worked for me - just like magic. I didn't even realize I had those tiny buttons on the bottom of my keyboard and mouse.
Here's what I did: 1. Change the batteries, disconnect everything, reconnect. 2. push the reconnect button on the top of the wireless keyboard/mouse receiver. 3. Use a wire (unbent paper clip) to push the tiny buttons on the bottom of the keyboard and mouse.
I have replaced the batteries in my mouse many times, but I think this is the first time I ever replaced the batteries in my keyboard. I think those batteries died and caused the problem that required me to reset the keyboard.
Thank you!
Linda
Posted on Oct 02, 2009
  • 21 Answers
I had a similar problem with this keyboard. My mouse worked fine, but the keyboard stopped working. I switched out the batteries, rebooted, etc and still not working.
BUT I realized that I had an issue with the batteries ... the first battery that I put in was getting jammed and was very difficult to get out. So I checked to make sure that the spring was working and I found out that whatever kind of spring was inside the battery case did not have any spring left or was gone. So my batteries had too much space to wiggle and hence could not supply power to the keyboard.
My solution is to roll up a small bit of aluminum foil and put inbetween both batteries.
Posted on Jul 17, 2009
  • Tammy Falisiano Jul 28, 2013
    This was my problem too. I put tinfoild between the batteries to make the full connection and all is good. I guess my spring was sprung too!
Solution 2 and 3 were right on the money. I spent several hours trying to get it to work. Mouse was OK, but the keyboard was not. I even had the installation CD, but for some reason it did not work.
Everybody, press both buttons at the same time and keep them both as close as possible when doing it. After that you can seperate them as you want with no problems.
Thank you for having this site up with all of the information...
Posted on Nov 23, 2009
He resuelto mi problema, mi teclado no funcionaba..le oprimia las teclas correspondientes y me daban otras !! La solucion fue muy simple: Oprimi un boton que esta por debajo que dice "Conect channel " y despues oprimi el "Wireless optical desktop receiver 2.1 " y listo !!
Posted on Mar 18, 2010
  • 490 Answers
If u instole drivers of keyboard ,open the software application settings and try to search for keyboard if detected than try using it
Posted on Oct 17, 2007
How to turn on the microsoft wireless keyboard 1.0a
The Microsoft Wireless Optical Desktop 1000 hardware set includes the Microsoft Wireless MultiMedia Keyboard Version 1.1a, Microsoft Standard Wireless Optical Mouse Version 1.0a and the Microsoft Wireless Optical Desktop Receiver version 2.1a.
The receiver connects to your computer through a USB port.
The product installation CD that ships with the hardware set includes the software drivers that are required to install the Microsoft Wireless Optical Desktop hardware on your Windows computer.
Insert the batteries that are included with the hardware set in the keyboard and mouse.
The battery installation latches are located on the bottom of the hardware devices.
Place the product installation CD in your computer's CD drive.
The hardware installation wizard will open automatically.
Plug the receiver into an open USB port on your computer when prompted.
Follow the wizard to synchronize the mouse and keyboard with the receiver.
Close the wizard when it finishes to complete the installation process.
http://www.microsoft.com/hardware/mouseandkeyboard/ProductDetails.aspx?pid=058
Jun 29, 2013 | Computers & Internet
What's the prices/rate of Microsoft wireless optical desktop receiver 2.1 model 1028, Microsoft standard wireless optical mouse model 1025 and Microsoft wireless multimedia keyboard 1.1 model 1014
Microsoft wireless optical desktop receiver 2.1 model 1028 - varies from Rs. 1900-2200
Microsoft standard wireless optical mouse model 1025 - varies from Rs. 400-600
Microsoft wireless multimedia keyboard 1.1 model 1014 - varies from Rs. 700-900
Dec 07, 2010 | Computers & Internet
I have a clight problem with my mouse and keyboard set i got it from a friend of the families becasue it was getting interferance when they tried to use it (can't change the freqency it uses) anyway long...
Wireless connections are not reliable. One solution is to buy a wired keyboard and a wired mouse. Depending on where you live, they can be obtained for $10 and last for years.
May 01, 2017 | Microsoft Wireless Optical Mouse
Keyboard problems
do the wireless connection in between the kbd and the computer again....
Apr 25, 2009 | Microsoft Multimedia Keyboard/Wireless...
Moving mouse, interrupts typing on MS Wireless Keyboard Combo
1.?Open the Start?Menu and click Devices?and?Printers . The Devices And Printers panel opens, in which you can access all the external devices connected to your computer, including your printer .
m-ydpxpf3wblkuljzof3anecxv-4-0.png Windows 10 - Control Panel - Keyboard - Settings
Apr 11, 2017 | Microsoft Multimedia Optical...
Microsoft Multimedia Keyboard 1.1
my microsoft wireless multimedia keyboard 1.1 does not function at all
Sep 02, 2008 | Microsoft Multimedia Optical...
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
Wireless keyboard
http://www.microsoft.com/hardware/mouseandkeyboard/default.mspx
Find your product on this page.. there are several drivers listed but since I do not know which OS you are using I can not be more specific
Mar 07, 2008 | Microsoft Multimedia Optical...
Computers & Internet Logo
16,922 people viewed this question
Alun Cox
David Payne
David Payne
