Question about Performance Teknique ICBM-752 Coaxial Car Speaker
Kenwood 138 and Performance Teknique 752 speaker problem
Bought used car with no radio. Had a Kenwood 138 radio installed but only occasional sound. I checked the speakers which are Performance Tekinique 752's which are 4 ohms 400 watts peak. When I press on the element, I get sound. Are the speakers bad? What 5" speakers do you recommend that are not too expensive.
  • 655 Answers
Hello passionatete,
It sure sounds like the speakers are bad. When I looked these up, the specifications said they are 5 1/4 inch. You should listen to a few different speakers in the size that you require, to see what ones you like best. I'd first make sure of the exact size. Many 5 1/4" speakers have tabs that allow them to be mounted in 6 1/2" openings. The best way to determine which speakers fit is to use the "outfit my car" feature at www.crutchfield.com. They have speakers starting at around $35 per pair. Another good online site for research and for purchase is www.sonicelectronix.com. Sonicelectronix sells speakers starting as low as about $20 per pair.
Kenwood, JVC, Sony, Blaupunkt, and Orion are all excellent speakers for under $30. There's others like Boss, Scosche, Power Acoustik, and Visonik that cost even less. Again, I'd listen first, and then buy.
Hope this helps.
Posted on May 17, 2009
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
Amp works on low side and full no high side
high level inputs are for speaker level inputs.Like if you used speaker wires right off your radio for input.Low level inputs are rca type inputs
Dec 19, 2012 | Performance Teknique Icbm-770 Monoblock...
I just purchased a new kenwood KDC-138 head unit as well as two car speakers. The speakers were able to be installed onto my 2000 mercury cougar but the head unit gave me some troubles. The wires on my new...
The following will help you out. The first is for the vehicle and the second for the stereo. Good Luck.
Constant 12V+ Orange/Black Switched 12V+ Yellow/Green Ground Black/Green Illumination n/a Dimmer White/Green Front Speakers 6" Doors Left Front (+) White/Black Left Front (-) Gray/Black Right Front (+) White/Red Right Front (-) Gray/Red Rear Speakers 6" x 8" Side Panels Left Rear (+) White/Purple Left Rear (-) Gray/White Right Rear (+) White Right Rear (-) Gray
May 16, 2011 | Kenwood KDC-138 FM / AM Receiver
Is the icbm-9711 is a good product
I've never used the products before, but the amps are usually pretty good. I would go with a different company though. I would go with Pioneer, Kenwood, or even Alpine. I know they're a little more expensive, but they've ALL been making head units longer. Several years ago Kenwood hit their 25th anniversary.
Apr 12, 2011 | Performance Teknique Car Audio & Video
Speakers are not producing a clear sound in any mode
hi can you tell me what ohm speakers you have connected and did you ajust the sound menu in the radio make sure all colour coded wirering is connected properly if not this can lead to damaging the radio
Mar 19, 2011 | Kenwood KDC-138 FM / AM Receiver
Kenwood kdc-138, NO SOUND, CD PLAYER NO RESPONDING
First thing you need to do is make sure you dont have a short in the speaker wires.. if any one of them touches ground it kills the system.. then you have to remove all the wires and start over... disconnect the battery... remove all the speaker wires only and then turn it on and reset it... then again remove the battery from the car and install them all make sure nothing is touching then turn it back on and see if that works.. you can also test to make sure you speaker wires are good by using a 9v battery and touching positive and negative of each speaker to the positive and neg of the battery... JUST FOR A SECOND it will pop.. that means your wires are good and no shorted to that speaker.
May 12, 2010 | Kenwood KDC-138 FM / AM Receiver
Subwoofer option on my kenwood kdc 138 receiver
go to kenwood wesite to down load instruction manuals
Sep 13, 2009 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Jul 24, 2008 | Kenwood KDC-138 FM / AM Receiver
Not enough power delivered
This sounds like a gain setting problem on your amp. The best way to adjust is to set your volume on the head unit to about 75% volume and then adjust the gain up until it sounds distorted a little. Back it off jst enough for the distortion to go away and you are set. Only other thing to try is use a multimeter set on Ohms to test the resistance of your speaker configuration. Looks like 2000 is th peak power (not RMS) and is only possible at high current configurations. You are probably running at 4 Ohms, but this amp only puts out rated power at 1 ohm stereo or 2 ohm bridged. Many people say Performance Technique are overrated, so maybe not even what it is rated at - 350 x 2 @ 2 ohms bridged (probably only about 175 x 2 at 4 ohms bridged)
Feb 06, 2008 | Performance Teknique ICBM-9540 Car Audio...
Performance Teknique ICBM-752 Coaxial Car Speaker Logo
106 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
