Question about Refrigerators
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
My fridge has been accumulating water in the top of the fridge in a grill under freezer, and as it builds up it leaks until i tip fridge forward and tip it out but then it build up again. The freezer and fridge are always very cold and as it is a frost free i cant see where water would come from?
  • Rebecca Check
    Rebecca Check Nov 20, 2011
    I have a samsung frost free... my boyfriend removed the model number cos it looks messy! GRRR!! and its doing the same thing. It leaks water from the vent between the fridge and freezer intermitantly... where is my drain hole to unblock it?
    President:
  • 1,136 Answers
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
Posted on May 17, 2009
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
What can i do to repair a leek from freezer to fridge?
1. Have you been able to find where the leak is?
2. After you find, get a spray foam filler or even bathroom caulking and fill the leak. Make sure it is dry before you seal.
3. If your fridge is old you could try STOP LEAK a very effective leak ender spray. This should have been #1 choice but I am afraid the grey spray may look messy A very effective solution..
Jul 16, 2013 | Computers & Internet
Water leaking from fridge roof
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Kenmore 64802 Top Freezer Refrigerator
E440t water pooling inside roof of fridge. then it leaks into fridge when its full. fan was noisy, now not making much noise. maybe its stopped.
THE drain in freezer is frozen over and the water is leaking into the fresh food / clean drain with hot water and turkey baster . this wil correct problem . some units need a drain heater installed to prevent it from doing it again .. mm
Aug 11, 2010 | Refrigerators
My tfx20 fridge, keeps icing up in the freezer. changed timer and defrost thermostat. no help. the fridge does stop on the set times on the timer but never defrosts. Fan is on constantly, no leaks from the...
If the frost builds up on the evaporator coil, sounds like the defrost heater may be out. Check continuity.
If the frost buildup anywhere else - there must be an air leak somwhere. Usually it's the gasket or the ice dispenser flap stuck open.
Vlad,
First Choice Appliance
Jun 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
Freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
May 10, 2009 | Refrigerators
Refrigerators Logo
298 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
