Question about Kenmore 30169 Electric Single Oven
When oven is set at certain temperature, it goes above set temp
    President:
  • 1,902 Answers
Bad thermostat, Your thermostat needs to be replaced. That is causing your temperature to go higher then what you call for
Posted on May 17, 2009
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
When I hit bake and then set the temperature the oven beeps and displays an F-4 code. The temp reading never goes over 100 so I thougt maybe the heating element was out.
The oven temperature sensor is defective.
Unplug the range or turn off the range circuit breaker.
Open the oven door,remove the oven racks.
The temperature sensor is a pencil thin metal piece about 4 inches long.
It protrudes from the rear upper part of the oven cavity.
Remove the mounting screw(s).
Carefully pull the sensor out to expose the molex quick connect plug.
Unplug the sensor.
Replace it with a new sensor.
Reverse the above order to secure the sensor and restore power.
Aug 22, 2010 | Amana Ovens
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
My GE gas oven temperature goes up and down a lot
The Thermostat on the oven might have to be replaced. This part is usually located behind the knob with the temperature settings. There is always a fluctuation in the temperature(usually 5% before the thermostat cuts the burner of and then back on. Other things can also influence oven temperature, like air drafts(usually caused by unrepaired or construction gaps in the wall on back of the range, but more often its the thermostat that need replacing. The following link can provide you with a further description of how the oven works: http://www.partsquik.com/appliancerepaircenter/Gasrange.htm I think you can also purchase your thermostat at that same site.
Jan 28, 2010 | GE Ovens
Oven only works at max temp
The oven temp switch should be replaced.
This switch has a long tube which goes from the switch to the inside of the oven. The switch can be replace without much of a problem but, feeding the new tube down to the oven can be tricky sometimes. The old tube will come out but you have to find the same hole to put the new tube back through, sometimes this will go through insulation and you can't see the hole where the old tube came out. It's not hard to do just be aware of this problem.
Dec 16, 2008 | Ovens
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Kenmore 30169 Electric Single Oven Logo
97 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
