Question about Kirby G4 Bagged Upright Vacuum
Cant rember how to replace the belt on the power head
The belt on the power head needs to be replaced
  • lilmissjen May 11, 2010
    sounds like you know how on the other heads-same!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off of the Kirby's driveshaft but on the "hook" inside the power nozzle) 2)Remove the power head from the front of the machine. Now that it is off the Kirby, you can turn the square belt lifter until the green arrows line up. (Belt on, which means on the driveshaft on the front of the Kirby when the power nozzle is on the Kirby which makes the brushes spin. Now that the power nozzle is off of the Kirby, the belt isn't actually resting on anything but the green arrows will still point to belt ON ) This removes the belt from the "hook" so that it can be slipped off the brush roll. 3)Turn the power nozzle upside down and release the two clips that hold the metal baseplate on and remove the baseplate. 4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. 5)Look at the ends of the brushroll. The brushroll has three height settings..you should see notches AND NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong. Also, one end cap of the brushroll is larger than the other and will only fit onto the larger notch in the power nozzle. 6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage. 7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place. 8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Posted on May 23, 2009
How do I fix the power head on Kenmore vacuum
Beater bar belt may need replaced. They stretch and will slip under a load. You should notice a burned rubber smell when the belt is slipping.
May 04, 2015 | Kenmore Vacuums
Brush bar not rotating. have cleared the head. suspect its the belt but cant get inside because the screws wont unscrew. could I need a complete new brush head . dyson is about 6 years old.
Hi there, it's Jack at Dyson.
DC25 doesn't have a traditional, user-replaceable belt. Instead, the belt is engineered to last the lifetime of the machine in normal use. The belt is protected by a sensor which shuts off the brush bar if something jams it. If the brush bar isn't currently rotating it's very unlikely to be related to the belt itself.
If you've been unable to reset the machine by removing any threads or hair from the brush bar and endcap, we'd appreciate the opportunity to take you through some further troubleshooting checks to pinpoint the cause of the issue. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking to you. If a repair or a replacement part is needed, we can also confirm if your DC25 is within the Dyson parts and labour guarantee period.
Please be aware that any remaining Dyson guarantee coverage on your machine could be void if you dismantle the cleaner head as you've described. For this reason we'd encourage you to get in touch directly for assistance rather than attempting a repair.
Feb 21, 2015 | Dyson DC25 Animal Bagless Upright Vacuum
I just need to get the power head apart to replace the belt. The two side tabs by themselves don't release the plastic...it is still firmly attached in the middle.
Look for a few screws under the machine, they will probably have Philips (star) heads. Remove these and the power head should come apart so you can access the belt and pulleys.
Feb 17, 2011 | Kenmore 23313 Whispertone Bagged Canister...
Need manual for kenmore power mate model No. 116. Need to know how to replace belt.
If you're talking about the belt that drives the brush in the power "head," you can replace it without the help of a manual. I did, and I'm certainly no mechanic. --Mike T
Oct 05, 2010 | Vacuums
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
Hi, my power head is not working on model 116 5416083 and I cannot open it up. I think there is a gasket that needs replacing.
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off from the base and you will be able to access the belt. Here is a link to the belt you need:
1165416083 Replacement Belt
Dec 03, 2009 | Vacuums
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
I have a broan central vac system need belt for cv315-b vac head cant seem to find one any idea where i can get 1 thanks
I believe that the Broan replacement part number for the belt for the CV-315 power head is a 9967-0585. available through a Broan/Nutone dealer.
May 11, 2008 | Vacuums
I have a Broan Nutone central vacuum. The power head seems to stall unless you lift up on the handle. I think I may need to change the belt but cannot find a place to purchase one to see if this is the...
If the power head is spinning when you lift up the handle then the head could be blocked with dirt. You may need to undo the floor head to see if the entire brush roll is clear as well as the main dirt channel/turbine wheel. Ensure that everything is clear before assuming it may be the belt that needs to be replaced.
You may well have to call or contact the main company who makes Broan Nutone models for them to send out / query the power head problem.
Apr 19, 2008 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
307 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
