Question about Husqvarna Garden
Engine runs backwards?
Husqvara CRT 50 rear tine tiller 4.5hp briggs . starts good. runs for a few seconds. then starts sceeching and winds the pull rope backwards.
  • billd126 May 18, 2009
    Model # 130202, type # 3129 01, code # 89112907
  • 376 Answers
Starter clutch needs to be cleaned or replaced. What is the model # and type # on the engine
Posted on May 17, 2009
  • Dwain Pippen May 18, 2009
    Yep, that the problem. It has the old style starter clutch with the ball bearings in it. Needs to be replaced. Part # 399671, about $11.50. You could try cleaning it. If you're so inclined, let me know and I'll tell you how. Dwain
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Have a sears craftsman 6.0 rear tine tiller.
Hi little,
The 7.0 hp version does the same thing.
I found that it was caused by the transmission not being fully engaged to a particular setting. when it tries to engage the tines in both forward and reverse, the engine stalls immediately.
After taking to neutral and back a few dozen times I got a 'feel' for it. Has happened in over a year.
Try it. It did take patience.
Best regards
Jul 16, 2010 | Craftsman Rear Mount Tiller
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Crt or srt tiller?
* CRT or SRT -- These are two terms you will see on rear-tine tillers only. o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground. o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Aug 27, 2008 | Mantis Electric Mini Tiller/Cultivator
Garden Logo
206 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
