Question about Sanyo PLC-XP46 Multimedia Projector
Green smudge on picture, maybe polarizer
Can the green polarizer be cleaned, or do it have to be replaced. If replaced what are the instructions to do so.
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
Hi, my HP2600N colour laser jet leaves two 1cm wide coloured smudge lines length ways on all my A4 prints. The printer is getting to about 2 years old now so i'm fearing that some major part needs...
Rest assure that the printer is fine and needs no major replacement.
Don't forget to convey your feedback
CreativeTECH
Jan 22, 2011 | HP Color LaserJet 2600n Printer
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
When i print it is having a smudges lines in the letter black only .how 2 solve it?
Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | Office Equipment & Supplies
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
There are black smudges from toner on the "green roller" of the cartridge. Please advise how to remove these - taking the unit out and cleaning all around, blowing out toner etc, has not worked. The unit...
You didn't include a model number, and "no" cleaning it and/or blowing it off won't help you -in fact may make things worse. The "Green roller" you talk about is the drum, it needs to be replaced - unless it's part of the toner cartridge, then that's all you need to replace.
Aug 28, 2009 | NEC Office Equipment & Supplies
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
The color is red and green, and theres two pictures on the screen, one red and the other green. how do you fix that?
you need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
Television has an extreme red tint
fluid comnated in blue crt and maybe in green
Jun 24, 2008 | Philips 43P8341 43" Rear Projection...
81 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
