Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Transmission locked up
Hello.
I have a craftsman 20 HP 48''mower automatic lawn tractor.It is locked up some how.on the back of the tractor there is a free weel lever.I pull it out so it will free weel .I tryed to push it ahead and back but it won,t disengage at all.BUT when i blocked the tractor up with both rear weels off the ground the right weel turns clock wize and the left side turns counter clock wize.i t has me baffled.if you can help me in some way i would be very greatfull thank you fore your time. TONY
  • 1 more comment
  • Anonymous May 18, 2009
    I have the same problem on a 25hp, 48 deck model. Will not engage, appears to be locked up. Belt unable to turn transmission assbly.
  • airmill May 25, 2009
    I have the same problem. Tractor is locked up even when in free wheel mode and when lifted up, the back tires turn in opposite directions.
  • Anonymous May 26, 2009
    I have the same problem with a 20 hp 42 inch cut mower rear wheels will not turn unless mower is picked up then only one side will turn.
By this time you have most likely solved or fixed the problem.Your brake is locked on even though you think it is not engaged.Most likely gummed up and it will require loosening up and lubrication.
This is a problem with all ride-ons and should have been solved years ago.
Posted on Jun 01, 2009
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Craftsman Lawn tractor 20 hp twin clynder briggs with a 42 inch deck I need a model number the plate is unreadable
Maybe this will help.The mower deck part # 165892. Mower Deck Assembly 42" I not sure of the model # . I also don't know your tractor's model # either. This part # for the 42" mower deck,is installed on a 18.5 HP Craftsman Lawn Tractor. I believe there isn't any difference between a model !8.5 HP and a model 20.0 HP, tractor when it comes to a mower deck. B.Locke
Sep 14, 2015 | Craftsman Garden
My craftsman 20 hp automatic lawn mower kills when i try to back up
It may have a safety lock on it causing you to not use the blades in reverse. My 07 craftsman has that safety feature.
Apr 13, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
I changed the back tire on my craftsman riding lawn mower and now it will not go forward or backward. It runs fine.
There is a lever between the back tires which disengages the transmission so the mower can be pushed when not running. Chances are you must have disengaged this lever maybe by accident. If you push it back in, the transmission will work right again. Usually it is a wire with a loop on the end.
Aug 06, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to adjust lawn deck it too low on one side its 20 hp 46 deck
attached you will find instructions for this task on a DLT-3000, 48" deck. It should be quite similar.ae27863.jpgea7530a.jpg
May 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Nov 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
455 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
