Question about Maytag PYE4558A Electric Dryer
Where would the fuss be located on a pye2300ayw model drye Would it be on the back or under the top
    President:
  • 1,136 Answers
Hi, Yes the thermal fuse is located under the top and is fastened to the element housing on the right side. It has two white wires going to it. It comes in a kit with the safety theralstat. If you need any more assistance or need a place to order it, please let me know.
Thanks
Vic
Posted on May 17, 2009
How to remove back panel kenmore drye model 96292100
The back doesn't come off. The top pops up. It's held down with clips. Pry under the top it'll pop up from the front. Hinges in the back.
Next the front is screwed on. If you take that off you'll have access to everything inside
Jun 09, 2014 | Whirlpool LER5636P Electric Dryer
How to remove 40 amp green fuse
If your talking about one of the big thick relay fusses under the hood then take a pair of needle nose pliers and pull straight up it will probably require some force but it will come out. There should be a puller in the curicuit panel where the green relay is located and a smoll puller for the fusses under the dash. Good Luck!!!
Mar 13, 2011 | 2004 Dodge Ram 2500
PYE2300AYW dryer doesn't heat up, but vent system ...
May 20, 2010 | Maytag PYE2300AY Electric Dryer
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300YW will not turn
maytag performa's have a thermal fuse located by the heater element located under the top back left corner
Also check for correct voltage to dryer
Nov 04, 2009 | Maytag PYE2300AY Electric Dryer
Blower motor is under the hood on firewall, but blower motor resisitor is nowhere to be found under the hood.
if you have the receiver drye of you a/c system near the blower motor, the resistor as a 4 wire plug wich should be on the right and top side of rubber cover
Jul 08, 2009 | 2000 Oldsmobile Bravada
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Where in Thermal fuse located maytag model #PYE2300AYW
Take the top off the dryer and you should find it located at or near the drum.
Jan 17, 2009 | Maytag PYE2300AY Electric Dryer
How to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE4558A Electric Dryer Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
