Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Bakground of the photo is a bit blurry
Hi I have Nikon D40 camera with standard 18-55 mm lens. The problem I have is when I made a photo during the day background is a bit blurry. for example the person looks fine but the objects around him are blurry.
What kind of settings I need to change.
Thanks for your help.
This is, in most cases, a desired effect (bokeh) which is used to "detach" the subject from the background avoiding the viewer of the picture to be distracted by the background. This technique is widely used in portraits. This effect effect will be more pronounced when the lens is wide open (in your case it should be f/3.5 if I remember well...). To practice you may try the following: set you camera to "A" mode and take one picture of something (it should not be a landscape) using the smallest aperture after this take the same pic using the biggest aperture. With the lower f number you should get a blurry background and with the biggest the backgroud should be in focus!
Posted on May 24, 2009
Hi, i am using nikon d40 my problem is that i was using 18-55 lens after some years there was green spots on my pics when clicked,i started using 18-105 mm nikkor lens my problem was solved but now af
The D40 is a low end camera, but before you discard it, I would contact the closest Nikon repair depot (see the Nikon website for the location) and ask them for a repair estimate. You will then be able to decide if it is better to have it repaired or replace it with a newer model.
Jan 08, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d 40 will not focus, but pictures are clear
Your camera probably has a diopter setting around the eyepiece that can be set for your vision. Refer to your manual about how to set it.
Nov 13, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
The viewfinder of my Nikon D80 is grayish and blurry when it's off. I cant see a thing when I tried to use my 18-135 mm lens. I don't have a battery to reset it to its factory default settings. Do you...
There is chance that your settings are just off . Set your settings to AUTO and then try again to view in viewfinder .If you sre still unlucky then there is some problem in camera ,You need to take to service center to get it serviced . It will be problem in CCD sensor . It will cost you around $100 to get it repaired .
Hope this helps .
Apr 01, 2010 | Nikon Cameras
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Blurry pictures, HELP ME PLEASE!
I'm currently having the same problem. :[
You might want to check and make sure your lens in on the "A" setting and not "M". This can be found on the side of your lens.
Nov 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 SLR 6MP 18-55 Lens
I son't know how to turn a camera into an IR camera but I did find a website that shows you how to make a filter that allows you to take IR photos. You can make the filter yourself for free unless you don't have the items needed but then again the item needed are only a couple of dollars. Here is the link.
http://www.diyphotography.net/take_infrared_pictures_with_digital_camera_ir_filter
Nov 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Blurry, AF not working
Try resetting the camera to it factory condition ..... also open lens and clean the contacts...and then try
Oct 12, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Frustrated female with a stupid camera
hi ,
i am a d40 user myself and i dont have anything but praises for the little guy. check out this link from nikon guru kenrockwell . i think his userguide is even better than the nikon manual itself :)
http://www.kenrockwell.com/nikon/d40/users-guide/index.htm
Oct 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
How to set up 50 mm lenst for wedding photos .. and flash
Sorry this is too late, perhaps it will be useful to others. I hope you used a different lens for the wedding!
You can't use the 50mm 1.8 lens on the D40x unless you focus manually. This is because the D40x only supports autofocus with AF-S and AF-I lenses. The focus motor and drive mechanism for other AF lenses was omitted to make the camera smaller, lighter and cheaper.
Aug 14, 2008 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
197 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
