Question about Sony Handycam DCR-DVD505 DVD Camcorder
LCD buttons not working
Buttons on the LCD panel not working. i am not able to change menu on the screen and cannot play back recordings. now i can only record videos by using the recording switch.
i tried to reset. no improvement. took out the battery and fixed back. again no change in performance.
my camcorder is only 1 yr old. pl help.
  • 4 more comments
  • Anonymous Dec 30, 2007
    I have the very same problem!! the cam is only a year old as well....
  • Anonymous Jun 22, 2008
    LCD buttons not working. Can not finalize.
  • Anonymous Sep 26, 2008
    sony handycam dcr dvd 505 touch screen not in function
  • jsschettini Oct 19, 2008
    I'm experiencing the same issue, I'm thinking in open it my self to solve. Does anybdy try this?
  • joalmaco Dec 19, 2008
    I have the same problem. The touchscreen doesn't seem to work. when touching the screen options it turns in no result or result out of the specifications. It's like if image and switch are out of place.
  • Anonymous Apr 22, 2009
    Calibration did not work, but I did not know that the remote enabled you to navigate the touch screen menus. Thank you. Grazie
I haven't the solution, but this may help some users. The camera has a LCD calibration menu. If LCD doesn't work properly use the remote control to get in to it. Try to calibrate the screen. This may be some help however didn't work for me, because I got no response from LCD panel. To calibrate remove all data (disc and memory stick). Click play/edit button, then use the remote control to p-menu > setup > standard set > calibratio. good luck!
Posted on Dec 19, 2008
  • 4 Answers
Yes, I solved this!
But you have to be very careful!
In my case, when it was not waorking, I opend only the LCD screen part and carefully put thick paper at the below part where all connection come (at the bottom of the screen).
It mean a thick paper is puttet under the carbon connections.
I screwed back all I opened earlier!
One thing to mention that I turned the cam on when ever I was doing work with that!
That all!
It is woring for years! and I am happy to let you know because I also was searching on websites to get it solved. At last I took the resk, and got success!
Hope for the best!
Ekram, from Bangladesh.
Posted on Jan 13, 2009
Thanks joalmaco. I had the same problem. The LCD screen no longer responded to touches. My wife had recorded a funeral for a friend whose husband had passed. Upon trying to finalize the disk so we could make a DVD we discovered the touch screen no longer worked. I didn't know what to do and had actually bid on another camera on ebay. I saw your post and was able to use the remote to at least finalize the disc. So, thanks for that.
At first I didn't think the remote was working. It was, you have to understand how it works. you will use the arrows to navigate around the screen. Press the circle between the arrows to 'press enter'. For instance, when setting the clock, you have to 'press enter' on the OK button to move to the next field, then use the arrows (to move to the up or down arrow ON THE SCREEN) then 'press enter' to make the hours, minutes, whatever go up or down depending on which arrow is highlighted on the screen. You can't just use the arrows on the remote to make the hours, minutes, etc go up or down. You have to use the arrows to highlight the arrows on the screen, then use the circle in the center of the arrows on the remote to 'press enter'. Confusing. Sorry about that. It make help you with that last disc until you can get your Handycam repaired.
It seems like this is a common problem with these units. Sony ought to pony up and fix it for free. My Handycam is still in perfect condition.
I'll try the other solution for fixing the problem and let everyone know
Posted on Nov 01, 2009
I have somehow changed the language into Japanese from English whilst trying to change the date. Please tell me how to change it back and also to put in the correct date.
On mine its ..
switch on .(make sure its not recording)
Record start/stop on mine is beside to on/off button
menu button twice (second menu)
on this option screen its the second option down - press record to select.
from there you can select your language.
One you've done that its the same input method for date , you just select the date and time options.
Jan 22, 2014 | HD DVR Hd Portable Dvr With 2.5 Tft Lcd...
I cannot record, in the corner where it says record, standby, it flashes the number C:31:40 I have a new TDK Hi 8 120 and it keeps flashing. Please help, thank
when problem occur while cam is operating, the self-diagnosis function starts working, and may display the service mode display code. in your case, C:31:40, pertains to a part of the cam tape compartment mechanism called the drum that doesn't start up. issues could prevent you from recording, playing back tapes, rewinding or fas forwarding. t/s steps are: try diff tapes esp. w/prev recordings, reset cam (press reset button while cam is on, located just below the menu button, in the panel where the lcd screen goes to), power reset (remove batt and ac adapter and leave cam w/ any power source for at least a minute). if issue persists, unit will require repair. hope this helps.tnx:)
Jul 21, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
LCD not working
my samsung mini dvd had problem with recording, the screen would go black (though menu displays come up fine).
could do play back but not record.
i put it in the sun for awhile or in a warm spot and it will record and show display.
it is not a complete fix but worth trying (on top of the heater works good too). of course the fix doesn't seem to work when i REALLY need to record something.
also had stripes coming across screen recently on playback, gave it a good tap and the stripes went.
Jun 17, 2009 | Samsung Compact MiniDV Digital Camcorder
Sony TRV308 Camcorder is not picking up light when recording
Hi there and welcome to FixYa.
Do your videos come out dark when you play them back? Or Is it dark while you are recording?
If it's dark while you are recording, is it dark in the viewfinder, or the LCD screen?
If your videos come out dark when you play them back, check the manual exposure. Hit the exposure button and turn the sel/push execute wheel to change the exposure to lighter.
If you are looking through the view finder to record and it's dark, check to make sure the window is clean.
If your LCD screen looks dark while your recording, put the power switch to player, hit the menu button and scroll down to LCD, select it and turn the select wheel to brighter.
I had to guess at what your problem was due to the information you provided, so I tried to cover the most obvious. If I failed to answer your question, please comment and be more specific.
Hope this helps, and thank you for coming to FixYa.
Mar 20, 2009 | Sony Video Cameras
Rca rp5011a
Regarding RCA RP5011A
Turn on = Play + Menu (at the same time)
Turn off = Stop (will revert to just clock)
Selecting folders or changing options = Turn on then press menu to move through options and use the forward and backward buttons to change within options
Deleting a file within a folder = Select the folder through menu options (A or B) then exit menu (cycle through all options or press stop once while in menu) then press the forward key to cycle through files within folders (1 or 2) then press delete once to display "Del" next to file then press delete a second time to delete file.
Take batteries out to quickly reset recorder (will not lose saved files)
Jun 06, 2008 | RCA RP5011 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller (����) to go
through the images until the movie clip you
want to play back is displayed.
�� To view the previous image, press the
four-way controller (��).
�� To view the next image, press the
3. Press the button to start playing back
the movie clips.
�� To pause or resume movie playback, press the button again.
Dec 25, 2007 | Cameras
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony Handycam DCR-DVD505 DVD Camcorder Logo
586 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
