Question about Cobra 19 DX IV CB Radio
Cb transmitting problem
I have a cobra dx and it recieves very well but when you transmit all you can here is a feedback type squeal and you can not here what is being transmitted, I have a firestick tuneable anntenna with 18' of cable, is the problem a poor antenna ground or SWR, please help.
  • Dean Pitts
    Dean Pitts May 11, 2010
    Are you using the stock mic? Try testing with a known good mic. Make sure its wiring is configured for a cobra or uniden, not a midland. Midlands are wired different.
    When you are using the mic, how close are you to the unit? If you are usuing an external speaker, how close is it to the microphone while you are transmitting? You will get feedback, ie. squealing, if the mic is too close to the speaker.
    Problem Solver:
  • 26 Answers
If you have a power mic the gain might be to high or the mic gain on the radio. Also ground the raido case.
Posted on Jun 16, 2012
  • 1,139 Answers
Hello kaelea,
Check your ground wire and by your post I gather that you are user some form of headphone device, I say this because normally the speaker is off when the microphone is keyed. I would also check the controls on the headset if you are using one.
I hope this helps,
Thank you,
Posted on Oct 16, 2007
No transmit tx light does not go to red when keyed up. redio was pluged in backwards. has recieve.
its very easy to blow the transmit transistor circuit if shorted
May 10, 2015 | Cobra 29 LTD CB Radio
How to wire a HG M73 mike to a galaxy DX 959
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
It recieves and shows its transmitting but it get i get no response
check the radio out by listening to another radio at the same time you talk on yours .
Jan 08, 2011 | Cobra 19 DX IV CB Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 25 only transmit and recieve on ch 1
Hi, my name is John. Take the cover off the unit, and check for broken trace or loose solder joints around this area, ...hope this was helpful..Rate this solution on the four thumbs-up.....John
Jul 12, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 150 Lights up,and receives but does not
I know this is going to sound stupid but if you hit or should I say tap ot it will it transmit. If so then you have a bad soilder some where on the board if not its probably your voltage regulator gone bad.
May 22, 2010 | Cobra 150 GTL DX Base CB Radio
Gtl dx will not transmit below 26.955
First off, the 200 GTL DX is a 10 meter radio. Running it on 11 meters (CB) is illegal, as it is not FCC type accepted. If you go below 26.965 mhz, you are outside of the 11 meter band, and operating illegally.12 meters does not start until 24.930, so ultimately, the freq's between 24.930 and 26.965 mhz are restricted even to a licensed amateur radio operator.
Jul 09, 2009 | Cobra Radio Communications
not a good idea to do it yourself you need the proper equipment to do the alignment you must know what part is the transmit and what is the recieve.
Apr 10, 2009 | Cobra 19 DX IV CB Radio
Cobra 19 DX IV CB Radio Gets no signal at all
my only idea is the frequency that Canadians transmit/recieve on is different than us down south (in the USA). I know Europe and the UK use a different frequency range so my guess is that Canada uses a different radio frequency range than the U.S. making you unable to communicate with fellow radio users. You may be able to search the frequency range for Canada vs. the U.S. and see if there's a difference. Hope this helps...and again, it's just a thought.
Montana, USA
Jul 08, 2008 | Cobra 19 DX IV CB Radio
Cobra 19 DX IV CB Radio Logo
262 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
