Question about Refrigerators
Hotpoint ffm90a fridge freezer, everything is working fine, my interior light is not working even afetr changing the bulb, what could be the issue? Thank You
    President:
  • 1,136 Answers
Hi, Sometimes you need to tighten the bulb a little more. They feel like they are in but, it might go more. I have been on many repair calls for this reason. I would try that first. If that doesn't work. you will need to teat the light switch. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 17, 2009
Frige-Freezer not coming on!
there is really nothing You personally can do to fix it, oyu will have to call a serviceman, i reccommend sears. It is a internal circuit or wire that probably blew and needs to really be fixed by a professional.
Sep 14, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
My Hotpoint Fridge Freezer 187P has Blinking Lights
Kindly upload pictures of the two lights flashing. What does the writing next to the two lights read?
Dec 06, 2017 | Refrigerators
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge not cold at all.
check the adaptive deffrost control inside of the refrigerator compartment, more than likely thats bad.
Apr 05, 2009 | Freezers
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
