Question about HP Computers & Internet
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
i did the above procedure and the ZIF connector that secure the keyboard cable to the motherboard broke.
Does annyone know how can i replace it or fix it?
my loptop os dv9000
Thank's
Posted on Jan 19, 2010
  • 71 Answers
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Posted on Jul 03, 2009
3 Suggested Answers
  • 452 Answers
SOURCE: hp pavillion tx2000 all lights are on - hard
That's a very common issue with that model, You will have to reflow the GPU with a heatgun. You can find more info from http://www.msbin.com if needed.
Posted on Mar 09, 2010
jcrowder0846
  • 470 Answers
SOURCE: Need to replace screen an an HP dv2-1118
There are tutorials at Youtube,com on how to do this go there and type in your make and model and how to replace a screen on your model. It is simple for those who have done it. On the screen itself will be rubber plugs those are the covers for the screws. Make sure to mark all wires and replace them exactly the same as them came off draw a diagram.
Remove the back of the laptops and locate the two wires they are grey and black usually these are attached to the Network Card clips be sure to replace them back the same way when done. You will also have to remove the plate the long one in the front where the power button sits and the speakers are located. There are approx 3 or four screws under the battery remove the battery and any screws that hold down the hinges. Remove the plug for the monitor from the lower case as well. You can now remove the whole screen.
Important: Do not touch where it says do not touch along the top of the screen is a sealed ban plastic do not push on this or handle it any other way but the edges. Replace everything the same way it came off and be sure no wires are pinched etc. Power up and off you go.
I suggest the video tutorial Click Here please. John
Posted on Apr 10, 2012
My hp pavillion ze4900 laptop is having display problems. It works if you plug it in to the moniter but either way if you don't plug it in or not. the laptop itself will not picture anything. Well i can...
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 10, 2010 | HP Pavilion Ze4900 Notebook
The display on my HP Pavillion dv1000 is extremely dim and I can't get the screen to lighten so I can read it. I have done a hard reset and replaced the power inverter. It blink on once, but that was the...
Oct 04, 2010 | HP Pavilion dv1000 Notebook
Princeton 19 inch LCD blinks and chirps. i need a
Here is a direct link to the HP Pavilion zd7310 maintenance & service guide:
http://h10032.www1.hp.com/ctg/Manual/c00218664.pdf
Nov 26, 2009 | HP Computers & Internet
Hp pavillion tx2000 all lights are on - hard
Oct 15, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion laptop won't backup to optical drive...CD/DVD-RW; I do have 1 Click Copy (&Pro) installed as well as DVD43. I have tried to uninstall the DVD43 & 1 Click but it doesn't change...
HP Pavillion laptops and every others laptops do require CD/DVD recordable for backup not CD/DVD rewritable. Try to use a CD/DVD recordable to see what will happen first.
Sep 16, 2009 | HP Computers & Internet
I need a wiring diagram for an HP Pavillion x1914 power supply. Son brought it home and all wires were pulled out and a new power supply ordered. It's here but he left me a mess.
try this site mate :
http://search.hp.com/gwukeng/query.html?lang=en&qp=&h_audience=&qt=+wiring+diagram+for+an+HP+Pavillion+x1914+power+supply&la=en&hps=&charset=UTF-8&cc=uk&submit.x=6&submit.y=5&hpo=&hpn=
Aug 12, 2009 | Computers & Internet
What to do when I dont get the LCD display in hp pavillion tx1000
Hi
did you see start up screen if not then just clean your RAM & remove your battery & plug in then try if u face same problem then send me more details
Harry
Jul 15, 2009 | HP Pavilion tx1000z Notebook
Hp pavillion wont boot, i just get a black screen
hello
I have read your problem and I think its a sure case of gone RAM.
Replace the RAM with a new one and your system will work fine.
Thank You
Jul 11, 2009 | HP Pavilion dv9000z Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
3,324 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
