In canon lbp2900b printer avilable in 600-1200 dpi resolution but when print matter in photo & images 300 dpi solution is best print quality in single colour so please any software in canon printer avilable in 300 dpi solution
SOURCE: Canon ir C3200 Print Resolution
Print out a Fiery config page ....there may be something in the fiery settings on the actual Fiery box, you'd have to reboot and run setup when it prompts you.
SOURCE: How to check total printed pages in canon LBP2900B printer
press resume button at least 4 seconds
SOURCE: How to set resolution 300X300 dpi
ok goto start /control-panle/display /change isplay settings then drag pointer to ur number/then apply
SOURCE: How do i set the output resolution to 600 x 600 dpi on a canon mp
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-PIXMA-MP600-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
SOURCE: Can anyone tell me how to reduce the DPI of Canon LBP 3050 Printe
Check in the printer properties. You can access this from the printer setup option as you start to print. Click on the Properties button next to the drop down for selecting the printer. Then click on the Quality tab. Alternatively, you can do this from the Control Panel in Windows. Hit Start > Devices and Printers (Start > Settings > Printers on some of the older versions of Windows). Right click on the printer and select Properties or Left click (once) on the printer and choose File > Properties. Again look for the Quality tab. In the Quality tab, you will be able to toggle between the available resolutions. Click Apply to set the setting and then OK when done. (You can also adjust the darkness of the text with the Brightness and Contrast sliders on this tab).
I hope this helps.
Testimonial: "Thnx a lot.this is realy helpful, but can i reduce dpi by reducing the toner density.Now it is kept in -4. Now can i decrease it to -5 or more to decrease dpi? "
ā¢ An image is defined by its pixel dimensions - # pixels tall by # pixels wideWhether you're a blogger dealing with an upload limit or are just trying to print a photo to hang on the wall, understanding DPI/PPI can go a long way. I hope these tips help you feel more in control of your images and how you share them with the world!
ā¢ DPI/PPI determines the scale and pixel density at which image will be displayed
ā¢ What appears blurry from close up may look fine at a distance, so consider how an image will be seen
ā¢ Printers can produce a range of DPIs, while displays have fixed resolution
