Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
How/where do I turn on the gas to start it
PGE came by my home to check for gas leaks. they also check the pool heater, which worked perfectly. They also turned the gas off to the pool heater since I wasn't using it. how do i turn the gas back on so when I turn the heater on it works. Hayward H-series
    Problem Solver:
  • 5 Answers
Open shut off valve out side of heater and turn gas valve (inside of heater) to "ON"
Posted on Jun 07, 2009
Leaks
check gas pressure if not correct will overheat and will start leaking
Jul 07, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Hayward H100ID1 heater. I turn the gas shut off on and I know there is gas going into the heater. But when I turn the heater on and it sparks, the is no gas smell and it does not light. What can...
first be sure your water filter is clean and the pressure gauge works.....you may need to bleed the gas line to get fresh gas to the unit, you can use soapy water to check, that the fitting leak free, after bleeding at the block
Jun 04, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I just purchased a home with a pool that has a H-series pool heater, stupid question but how do I start it. There is no indicator lights on the keypad. thanks
Hello and thanks for choosing FixYa
Your pool heater should be powered only when the pool pump is in operation. When you turn on the pool pump the indicator lights should on the heater should also come on. You should also check the breaker for the heater located at the sub-panel in the pool heater area. You can also try flipping off the breaker and the turning it back on to see if it was possibly tripped or sticking.
If you have the pool pump in operation,verified the breakers are on,verified that there is power to the heater then it is possible that pool heater has a malfunction. I recommend that you call a pool company to have this equipment serviced. Gas appliances can be dangerous due to possible fire or explosion so any other repairs would be made at your own risk.
I hope I was helpful and thanks for using FixYa
Dec 29, 2010 | Hayward H-series Electronic Gas Pool...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
I have a gas leak
If the valve "in the heater" you are talking about is the main gas valve, check the regulator, which should be before the main gas valve.
Jun 20, 2010 | Hayward 2001 Series Millivolt Gas Pool...
Pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Jul 21, 2009 | Hayward H Series Pool & Spa Heater 400k...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
I'm trying to start-up a Hayward H400 natural gas heater for my pool. It was brand new last season and worked perfectly. It keeps firing up for a little while (maybe 10 seconds on average) and then shuts...
if means ignition failure check that gas is on, check for fauilty igniter wiring or connections, inspect gas valve wiring measure voltage across gas valve during trial to ignition if 24 volt replace gas valve if no 24 volt replace control module
May 19, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
154 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
