Question about Dryers
Drum seal replacement
I need to replace the drum seal on my Kenmore electric dryer model# 11062622100 and I want to know how to remove the front panel?
    President:
  • 1,136 Answers
Hi. You need to remove the two screws located under the lint screen lid. Now take a flat screw driver and pry upward between the top and the front panel. Now you look inside upper corners and you will see two 5?16" screws. Remover them and the front will lift up off the clips at the bottom.
Notice the belt and how it threads through the idler pulley and goes on the drive motor pulley. It can be difficult so look closely.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 17, 2009
On a series 90 kenmore dryer where is the belt front or back
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Anwer to your question: Front
Basic Information...
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Sep 30, 2010 | Kenmore 64952 Electric Dryer
Replacing dryer drum Kenmore Elite Electric Dryer
Usually from the front. Lift top and remove front. I can't image it would be worth replacing the drum. What is wrong with the drum? or do you mean the belt to drive the drum.
Jul 25, 2010 | Kenmore Dryers
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 07, 2009 | Dryers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Dryer is making a grinding noise
Am so happy to assist you with this issue
http://www.youtube.com/watch?v=S5hVeShxLkc
your raitting is very important for me
was thsi helpful?
May 21, 2009 | Kenmore 63942 Dryer
Dryer leaves brown spots on clothing articles. Suspect back seals as gaps are evident and drum is loose within the unit. What is remedy? Cost of seal replacement?? Kenmore 62802 Electric Dryer Deb in Brown...
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Mar 23, 2009 | Kenmore Dryers
Kenmore Dryer Drum is very loose and noisy.
It sounds like one of the rollers has a bad bearing. You will need to take the front off the dryer, unhook the belt, and remove the drum to check the rollers.
Nov 20, 2008 | AEG T57800 Electric Dryer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Kenmore he4 dryer model # 110.85089400
drum seal tends to change to a rust color after a few years of use 2 options replace both front and rear seal(best) or remove drum and try to clean both seals with bleach /water solution or spray cleaner with bleach ..if seals are not worn to bad this may work as a tempory fix
Jul 04, 2008 | Whirlpool GEW9250 Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Dryers Logo
206 people viewed this question
Top Dryers Experts
