Question about iLO 3200 32 in. LCD Television
Lousy sound have digital tv ilo iwt3206 with no audio out?. can this been hooked to a sourond sound receiver
    President:
  • iLO Master
  • 1,779 Answers
If you don't have the Audio Output RCA jacks on the back then you can't. The other way would be to have a cable box and use the audio out from there.
Posted on May 20, 2009
Where is the hdmi connection?
The Ilo IWT3206 is a CRT type TV; it does have an ATSC tuner to support digital OTA TV signals. It doesn't have an HDMI port. The best input it has is the component video in. There are HDMI to component converters. However, most of them have issues with digital rights management protections (HDCP). The manual for the Ilo IWT3206 is available from the manufacturer (Funai). Their support page is at http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is http://www.funai-corp.com/support/om/IWT3206.pdf .
I wish that I had better news for you. If you have a different model, please post a comment or a new question.
May 15, 2015 | iLO IWT3206 TV
How do i hook up a audio/video reciever up to my tv...Which plugs in tge back of tv do i use
red and white are for audio. Yellow is for video. HDMI will supply both audio and video
Mar 13, 2015 | iLO IWT3206 TV
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
My ilo hdtv doesn't have a cable hook up
Going to have to connect (no coax fitting means it is a monitor with no tuner) via one of the rear audio/video inputs with a box that has those outputs on it.
HD is almost always connected in this way.
May 02, 2012 | iLO IWT3206 TV
Does ilo model #IWT3206 television have reset button ?
It does not appear to have a reset button or any type of reset menu option. http://www.funaiservice.com/manual/ILO/Manual/IWT3206.pdf Some TV's will reset by simply unplugging them from the AC outlet for 1-2 minutes then plugging them back up.
Jan 31, 2012 | iLO IWT3206 TV
S-viedo from laptop to ilo model iwt3206 is it possable
Can't do an s-video just hook up rgb/vga cable from laptop to tv and put the input to rgb/vga.
Nov 20, 2011 | iLO IWT3206 TV
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Televison & Video
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Getting alot of "no signal"
You will need a digital antenna for reception. You do not need a converter box for your tv. I have a digital antenna and get a bunch of channels in.
Apr 05, 2009 | iLO IWT3206 TV
I am not using cable or dish...what type of antenna should i use to get the most out of the digital conversion...and is the built in converter adequate or do i need converter box?
The specs for this TV shows it has ASTC and NTSC so you do not need a converter box.
Almost all the Digital channels are broadcasted in the UHF band.
When you scan in the channels the VHF numbers will still show but the actually signal will be in the UHF band.
Go to
WWW.TVFOOL.COM and enter your ZIPCODE to get the stations in your area.
MPN: IWT3206 Key Features Digital TV Standard: SDTV Diagonal Screen Size: 32 inch Display Capabilities Built-in Tuner: ATSC · NTSC Image Quality Comb Filter: 3DYC / 3D Digital Audio Features Audio Type: Stereo SAP / MTS Stereo: SAP / MTS Stereo Technical Features Sleep Timer: With Sleep Timer Connectors Rear Input Connectors: Composite x 1 · Audio (RCA) x 1 Front Input Connectors: Composite x 1 · Audio (RCA) x 1 Screen Text OSD Languages: English · French · Spanish Miscellaneous Product ID: 37594421 More Information Details: Big picture, small price. Enjoy watching your favorite, sports, programs and movies on this generously-sized 32" TV from ilo. The side stereo speakers help create a richer sound experience. Even more conveniently, the built-in digital (ATSC) tuner accesses digital content without the need for a separate set top box that takes up space. And since the screen delivers standard definition (SD) resolution.
iLO 3200 32 in. LCD Television Logo
75 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
