Question about Alen C320 Portable Air Conditioner
The alen c320 will blow cool and after a few minutes will stop blowing cold. Could it be running low on freon? Please respond to azjackrabbit@gmail.com
  • 148 Answers
Yes very posibble
Posted on May 17, 2009
2004 sebring air conditioner stops and starts
Low freon will cause the compressor to short cycle, when the compressor runs the pressure in the low line is pulled down and the low pressure switch turns it off. Not running the pressure builds up and turns it back on. In the old days there was no low pressure switch, with no freon to carry the oil the compressor was destroyed.
Jun 28, 2014 | 2004 Chrysler Sebring
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Air conditioning freezes up
Could be low on freon, a restriction in the system, or electrical problem.
Jul 10, 2012 | Ford Cars & Trucks
AC blows cool not cold, checked freon seems to be
I dont know how you can check it for being full or not? but most likely its low. If you have it on, and high speed like 2000 rpm and the a/c clutch goes on/ off in a few seconds, the refrigerent is low.
May 12, 2010 | 1992 Ford F150 SuperCab
Air Conditioner stops blowing cold air when vehicle is not moving
plus one on the cooling fan problem. if it was low on charge then as you slow down, condensor temps and line prressures would raise therefore it would cool at low speed and and not when moving since the incoming air would drop system temp,reducing line pressure and then cusing compressor to cycle. the auxillary cooling fans must be on whenever a/c is on, if not, thats your problem. get this taken care of because if you get stuck in traffic, your engine will overheat also if fans are not running
Sep 02, 2009 | 2007 Ford Five Hundred Limited Sedan
Rv unit blows cold for a few days then blows hot.
make sure temp sensor stuck in coils or unit low on Freon cannot refill
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
2003 Honda Accord blows cold airwhen started up but quits.
IF THE SYSTEM IS LOW ON FREON, THEN AFTER RUNNING FOR A FEW MINUTES THE LEVEL OF LIQUID IN THE ACCUMULATOR DROPS AND SHUTS OFF THE COMPRESSOR. YOU MAY JUST BE LOW ON FREON. HOPE THIS HELPS. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. BEST OF LUCK. PLEASE KEEP ME POSTED.
Aug 17, 2009 | 2003 Honda Accord
Ac system does not get cold
you should go to a mechanic and check the A/C if the freon id low it won't cool , some time at mornig it give you the semsation that is cooling but probably not..
Aug 01, 2009 | 1999 Volkswagen Cabrio
A/C does not blow cold air. It has frosting built on the pipe that connects to the a/c unit outside. There is some water built up where the filter sits. I turnd off the a/c for a full day, the frost...
Shelly,
Most likely you are low on freon. Your air conditioner uses a coil that gets cold when the freon passes through it to produce your cooling. The temperature of the freon inside the coil is directly controlled by the pressure of the freon. When the system is low on freon, it causes the coil to become to cold and then instead of sweating it freezes. You will need an a/c technician to reslove the problem for you as the task requires tools and equipment that you most likely don't have.
Thank you,
Chillmaster
Jul 03, 2008 | Heating & Cooling
Alen C320 Portable Air Conditioner Logo
102 people viewed this question
Top Alen Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Alen Heating and Cooling Expert? Answer questions, earn points and help others
